ECUFlash can work with Mitsubishi Outlander?
Dyno Chart and wide band lambda
Postby christian_piasini » Wed Dec 06, 2006 11:55 pm
Sorry, I forget.........
the dyno chart....
Chris
Dyno Chart.JPG (185.56 KiB) Viewed 11021 times
Outlander 2.0 Turbo done
Postby christian_piasini » Wed Jul 11, 2007 1:03 pm
Hi @ all, finaly the Outlander Flashing is done!
READ/WRITE of the MH8202F
regards
www.piasiniengineering.it
outlander turbo.hex
(512 KiB) Downloaded 1114 times
outlander 20T_reading.jpg (72.99 KiB) Viewed 10890 times
Postby RanEvo » Thu Jul 12, 2007 3:54 am
Hello Piasini,
are you going to share with us the software? :)
RanEvo
Hi @ all
Postby christian_piasini » Mon Oct 08, 2007 7:28 am
Here our dyno chart on the Outlander 2.0 Turbo.
removed speelimit
Higer rpm limiter
changed overboost valve
pressure drop 1.45 boost and 1.2 full rpm.
best regards
Outlander 20Turbo_202HP.jpg (211.89 KiB) Viewed 10793 times
Postby DarkECU » Mon Oct 08, 2007 8:35 am
this soft has been very expensive price
at the moment it can flash with cheaper tool than that
DarkECU
look at this... ;-)
Postby christian_piasini » Mon Oct 08, 2007 11:19 am
This is to show was removed the stock speedlimiter at 210Km/h!
have to know also what to do!
Speed testing2.jpg (261.19 KiB) Viewed 10776 times
Speed testing.jpg (1.38 MiB) Viewed 10786 times
Re: look at this... ;-)
Postby xor » Mon Oct 08, 2007 11:34 pm
christian_piasini wrote:This is to show was removed the stock speedlimiter at 210Km/h!
Maybe you better buy ads on this site, it would help more then screenshots without any usable information for the community.
xor
Postby RanEvo » Tue Oct 09, 2007 12:16 am
DarkECU wrote:this soft has been very expensive price
What tool can flash at this time the Outlander Turbo - by this time the EcuFlash can do it? :?:
RanEvo
Answer To Xor (see i don't know your name)
Postby christian_piasini » Tue Oct 09, 2007 12:33 am
Hei guy, i'm the first post there the dyno chart, the picture of the ecu, and the stock hex too of the Outalnder 2.0 T!!!!!
I think you have to give something to the comunity!!!!!!!!!
NOT me.................... ;-)
cheers
Re: RANEVO
Postby 0xyGen » Mon Oct 13, 2008 12:23 pm
KenYong3671 wrote:Hi RANEVO,
as for ur problem..i have found a solution for it.
initially, i have the same issue as u when i tried to read from the MIT Airtrek which is i think similliar to u problem.
just jumper the two wire from the openport wire white connector to the seconf init connector at ur car. and the third one to the pinj 1 of the ODBII of ur car. It works for me.
Hope u are able to get it.
pls share a another photo or diagrom for wiring ?
0xyGen
