NeverLies wrote:Have you read the DTC after the CEL was ON ? P302 is not the only DTC for misfire, it goes from 301 to 304. So you should disable these 4 DTCs
Freon wrote:I don't think I ever responded with an update for my situation.
The "0" in place of "1" fix on my 2004 STI USDM DBW AJ241 works fine for P0420. I haven't had a catalyst in my car in months. I do not read the code out ever, historical or pending with my simple Actron reader or Ecuexplorer. I had some confusion when I was doing a lot of map swapping whether or not I actually had the fix in the car, but it is definitely in now and definitely works. Some confirmation of each location is in order, but my P0420 "0" works for sure.
m3n0ch3 wrote:Can you give out the hex address of the fix you did?
