Hello,
I have tried reading my ECU memory but with no luck...
i have/use:
Openport 1.3 (subaru)
EcuFlash 1.29
Green connectors connected (both) car goes into diagnoses. Cel flashing, Fans cyling.
i have tried many times, different timing with the 'ON' switch, and it just doesnt want to read the rom...
Car is: 2005 wrx from Aruba, Caribbean
Do you guys think i need the white flash connectors? i have tried it once with it (was afriad to try again) and it didnt connect, the car stays in diagonses with the white flash connected.
I also have tried downloading ecuflash 1.28 but it doesnt work after install does anyone have a working copy?
i will post the logs below...
[02:30:29.193] Version 1.29.906
[02:30:29.193] 8 memory models read.
[02:30:31.456] 140 ROM metadata models read.
[02:30:31.456] checksum module "subarudbw" loaded.
[02:30:31.456] flashing tool "wrx02" loaded.
[02:30:31.456] flashing tool "wrx04" loaded.
[02:30:31.456] flashing tool "sti04" loaded.
[02:30:31.456] flashing tool "sti05" loaded.
[02:30:31.456] flashing tool "mitsukernel" loaded.
[02:30:31.456] flashing tool "mitsukernelocp" loaded.
[02:30:31.456] flashing tool "mitsubootloader" loaded.
[02:30:45.857] denso02_bootloader_cmd_start
[02:30:47.058] denso02_bootloader_cmd_start
[02:30:48.260] denso02_bootloader_cmd_start
[02:30:49.462] denso02_bootloader_cmd_start
[02:30:50.664] denso02_bootloader_cmd_start
[02:30:51.084] kernel get version
[02:31:09.591] ssm2_init
[02:31:09.761] ECU ID is 3D FFFFFFA4 58 30 05
[02:31:09.761] ssm2_cmd_0x81
[02:42:43.899] Version 1.29.906
[02:42:43.909] 8 memory models read.
[02:42:46.162] 140 ROM metadata models read.
[02:42:46.162] checksum module "subarudbw" loaded.
[02:42:46.162] flashing tool "wrx02" loaded.
[02:42:46.162] flashing tool "wrx04" loaded.
[02:42:46.162] flashing tool "sti04" loaded.
[02:42:46.162] flashing tool "sti05" loaded.
[02:42:46.162] flashing tool "mitsukernel" loaded.
[02:42:46.162] flashing tool "mitsukernelocp" loaded.
[02:42:46.162] flashing tool "mitsubootloader" loaded.
[02:43:20.382] ssm2_init
[02:43:20.552] ECU ID is 3D FFFFFFA4 58 30 05
[02:43:20.552] ssm2_cmd_0x81
[02:43:37.026] denso02_bootloader_cmd_start
[02:43:38.227] denso02_bootloader_cmd_start
[02:43:39.429] denso02_bootloader_cmd_start
[02:43:40.631] denso02_bootloader_cmd_start
[02:43:41.833] denso02_bootloader_cmd_start
[02:43:42.273] kernel get version
[02:43:53.579] denso02_bootloader_cmd_start
[02:43:54.781] denso02_bootloader_cmd_start
[02:43:55.983] denso02_bootloader_cmd_start
[02:43:57.185] denso02_bootloader_cmd_start
[02:43:58.386] denso02_bootloader_cmd_start
[02:43:58.807] kernel get version
[02:44:12.797] ssm2_init
[02:44:12.957] ECU ID is 3D FFFFFFA4 58 30 05
[02:44:12.967] ssm2_cmd_0x81
[02:44:27.759] ssm2_init
[02:44:27.919] ECU ID is 3D FFFFFFA4 58 30 05
[02:44:27.929] ssm2_cmd_0x81
[02:44:39.776] ssm2_init
[02:44:39.936] ECU ID is 3D FFFFFFA4 58 30 05
[02:44:39.946] ssm2_cmd_0x81
[02:44:54.527] ssm2_init
[02:44:54.687] ECU ID is 3D FFFFFFA4 58 30 05
[02:44:54.697] ssm2_cmd_0x81
maybe this isnt for me? should i go ahead and buy UTEC?
