JDM Legacy B4 RSK 5 manual 2000
Postby bb8 » Tue Dec 12, 2006 2:18 am
Hi ! I have Legacy B4 RSK from Japan BE5 2000 year. And my problem - where is a flash connector ? Green connector is ok. Logging is ok. But read ECU is not possible. Thanks.
bb8
Postby swiffly » Tue Dec 12, 2006 11:09 pm
from you find the green connectors under the dashboad, you should see the white connector. then again your car is a 2000 so you might not use them.
swiffly
Postby bb8 » Wed Dec 13, 2006 12:18 pm
I have found a white socket, but it is not similar on necessary. In it six wires.
bb8
Postby bb8 » Wed Dec 13, 2006 12:27 pm
I tried to read out ecu 8 times at the closed green sockets - it is impossible, the program gives a mistake ssm2 x081 . I have opened ecu and have looked near to it - no other sockets are present.
bb8
Postby bb8 » Wed Dec 13, 2006 12:33 pm
Program EcuExplorer defines type ecu as MY99 AG302, I think, that this type concerns to cars of type Drive-by-cable, and for them is necessary flash connector.
bb8
Postby bb8 » Thu Dec 14, 2006 12:54 am
I have read through here
http://forums.openecu.org/viewtopic.php?t=1322
that the type ecu UNISIA JECS which costs at me in the car, cannot be read through by means of EcuFlash. It is the truth? What to do?
bb8
Postby NoCtrl » Thu Dec 14, 2006 8:36 am
Also see the end of this thread for JECS ECU status: http://forums.openecu.org/viewtopic.php?t=192&start=210
NoCtrl
Postby bb8 » Thu Dec 14, 2006 11:33 am
Thanks, very interesting info, but ecu rom not read :((
bb8
Postby Kosti » Fri Dec 29, 2006 2:04 am
Did you end up dumping your ECU yet?
Kosti
Postby bb8 » Wed Jan 10, 2007 10:04 am
Hi !
No, ecu not dumped. Any idea ??
bb8
Postby cboles » Wed Jan 10, 2007 2:43 pm
JECS ECUs are not readable by EcuFlash at this time.
Postby bb8 » Fri Jan 12, 2007 1:29 am
Hi Colby ! Are you working with this problem ? May be I can help ?
bb8
Postby cboles » Fri Jan 12, 2007 4:17 pm
Unfortunately, I am not working on JECS ECUs at this time. I am focused on newer ECUs as well as the H8 for Mitsubishi.
Postby bb8 » Fri Jan 12, 2007 11:29 pm
It is very a pity. Are you planned to continue work in the future ?
bb8
Postby wopdeeze » Wed Jan 09, 2008 1:47 am
having the same problem with a 99 jdm legacy GT-B twin turbo with the 951 jecs ecu, any update would be great, i dont think my buddy wants to pay 1000 dollars to mines to do an ecu tune. next project is a 01 jdm WRX-NB that one should be fun
wopdeeze
