by swiffly » Sat Nov 18, 2006 9:58 am
ok i have had the same problem but i got a check light too. anyways i found a fix that worked for me.
what i noticed was that when u change too many things eg. fueling, timing boost and speedcut at the same time then flash them in, it gives me the error.
so what i do is change them one at a time and then flash. SO do fueling changes then flash, start the car to check for good work order - timing changes then flash, start the car to check for good work order - boost changes then flash, start the car to check for good work order
it takes up a lot more time but it works and the car responds to the tuning.
the next thing is the voltage drop. i noticed that when i was doing my routine boost flash like the above, i got the error again. the only thing i did different was to turn on the headlights while flashing. so when i tried again without doing anything that would alter the voltage or turn on any light, radio etc. it worked.
my 2 cents, hope it helps
