MY03 Legacy 2.0 B4 AUTO Twin Turbo AH650-4430 ADM
Postby Kosti » Sat Dec 09, 2006 5:45 pm
Well I finally got my cable and have queried my ECU. I am not sure I done this right, but here it is. Can someone please confirm and convert?
Thanking you in advance!
Kosti
EDIT Sorry this was a dump of what was in the flash memory
Please scroll further down for a full dump of my ROM.
Thanks for helping out
AH650-4430.hex
(8 KiB) Downloaded 668 times
Kosti
Postby Kosti » Mon Dec 11, 2006 12:34 pm
Looks like the above is wrong, will attempt to query the ecu again tonight.
Kosti
Postby Kosti » Tue Dec 12, 2006 12:08 am
Well I tried again to interrogate the ECU using ecuflash but no luck. I get a failed check log pop up.
I've attached the error log.
I used the green test plug and the other plug but still no luck, I had the car running, ingnition on / off.
Any idea's
EDIT OK this file is useless as with a little more reading I got it reading my ECU
Please look at my full dump of the ROM further down this page.
Cheers
Kosti
errorlog.txt
Error log when trying to read ECU via open port 1.3 cable
(1.39 KiB) Downloaded 622 times
Kosti
Postby Kosti » Tue Dec 12, 2006 12:18 am
I found this thread, so I will give this a try..
http://forums.openecu.org/viewtopic.php?t=1379
BRB!
Kosti
Postby Kosti » Tue Dec 12, 2006 1:07 am
OK, the above information thread helped and I got it working! phew...
For all us ozzies out there who don't have WRX but a Liberty B4 Twin Turbo you need to do the following.
[1] Find the cables and connect the two green plugs together, then plug in the white block connector as well.
[2] open up ecuflash and hit read rom.
[3] from the menu choose the year model for your car in my case 2003 which worked under 2001-2003 Subaru Impreza WRX :roll:
[4] Once ready you need to have your brant immoboliser off in order for it to set the ingnition to "ON" (this was what was causing my errors) But in other software like ecuexplorer I didn't have this problem, then actual name of the car would come up.
[5] This should then start the read process, once finished you need to save it some how to a xml, which is were I stopped.
[6] Turn off, remove test (green plug) and white loop block.
Hope this helps others. now to repost my ROM for definition request :D
Kosti
Postby Kosti » Tue Dec 12, 2006 1:22 am
Can someone please help with this file and confirm.
I just placed basic information and I am yet to get the case ID of the ECU and all the rest of the details. When I was trying to save this I had to pick wrxbase and then it added created what I think is my rom.
Anyways I'd like someone to convert this to to use the correct xml based on my rom.
AH650-4430.hex
MY03 Legacy/Liberty 2.0 B4 AUTO Twin Turbo AH650-4430 ADM
(160 KiB) Downloaded 1098 times
Kosti
Postby bb8 » Tue Dec 12, 2006 2:07 am
Hi ! I have Legacy B4 RSK from Japan BE5 2000 year. And my problem - where is a white flash connector under the dash ? Can you make a photo of your connector ? Thanks.
bb8
Postby Kosti » Tue Dec 12, 2006 2:22 am
bb8 wrote:Hi ! I have Legacy B4 RSK from Japan BE5 2000 year. And my problem - where is a white flash connector under the dash ? Can you make a photo of your connector ? Thanks.
Hi mate,
It's located near the clutch or foot rest once but u have to remove the under the steering console, once you find the green connectors the white one is there, (there is no plug in the white conector and the green ones are disconnected.
Check this links for a pictures
CLICK
CLICK 2
Hope this helps you out !
Cheers
Kosti
Kosti
Postby bb8 » Tue Dec 12, 2006 2:45 am
Fantasy. But on mine car such socket is not present! Near to green connector, where or around. I shall make a photo in the evening and I shall lay out here. Similar, artful Japanese use any other way.
bb8
Postby Kosti » Tue Dec 12, 2006 12:12 pm
bb8 wrote:Fantasy. But on mine car such socket is not present! Near to green connector, where or around. I shall make a photo in the evening and I shall lay out here. Similar, artful Japanese use any other way.
Hi bb8,
You may not need this cable, since it was for 2003-2005 models and since yours is 2000 RSK B4 it may only need require the green connectors.
Join the two connectors together and try to read your ECU.
Good Luck
Kosti
Postby Kosti » Tue Dec 12, 2006 12:13 pm
Kosti wrote:Can someone please help with this file and confirm.
Can someone convert to XML Definition for this hex dump?
I want to be sure I have dumped the ECU correctly.
Kosti
Kosti
Postby bb8 » Wed Dec 13, 2006 12:36 pm
Hi ! I tried to read out ecu 8 times at the closed green sockets - it is impossible, the program gives a mistake ssm2 x081 . I have opened ecu and have looked near to it - no other sockets are present.
Read
http://forums.openecu.org/viewtopic.php?t=1562
bb8
Postby Kosti » Wed Dec 13, 2006 10:48 pm
What no love?
Doesn't anyone wanna help and confirm the if the file is correct and possible make me a def for it.. :roll:
Kosti
Postby Kosti » Mon Dec 18, 2006 12:53 pm
OK, seems this site was unreachable for a few days, back now.....
So the champion team @ enginuity helped me out heaps. This ROM is the base ROM and has been extracted fine.
Thanks to all that helped!
PEACE
Kosti
Kosti
Postby Kosti » Tue Dec 19, 2006 9:40 pm
Hey All,
There are a number of 1D, 2D & 3D parameters that come up as either a ? or unknown.
Is there anyway to try and find out what there names or labels are?
Anyone?
Kosti
Kosti
Users browsing this forum: No registered users and 51 guests
