2005 cant connect (read)
Postby wrx_aruba » Wed Dec 13, 2006 6:40 pm
Hello,
I have tried reading my ECU memory but with no luck...
i have/use:
Openport 1.3 (subaru)
EcuFlash 1.29
Green connectors connected (both) car goes into diagnoses. Cel flashing, Fans cyling.
i have tried many times, different timing with the 'ON' switch, and it just doesnt want to read the rom...
Car is: 2005 wrx from Aruba, Caribbean
Do you guys think i need the white flash connectors? i have tried it once with it (was afriad to try again) and it didnt connect, the car stays in diagonses with the white flash connected.
I also have tried downloading ecuflash 1.28 but it doesnt work after install does anyone have a working copy?
i will post the logs below...
[02:30:29.193] Version 1.29.906
[02:30:29.193] 8 memory models read.
[02:30:31.456] 140 ROM metadata models read.
[02:30:31.456] checksum module "subarudbw" loaded.
[02:30:31.456] flashing tool "wrx02" loaded.
[02:30:31.456] flashing tool "wrx04" loaded.
[02:30:31.456] flashing tool "sti04" loaded.
[02:30:31.456] flashing tool "sti05" loaded.
[02:30:31.456] flashing tool "mitsukernel" loaded.
[02:30:31.456] flashing tool "mitsukernelocp" loaded.
[02:30:31.456] flashing tool "mitsubootloader" loaded.
[02:30:45.857] denso02_bootloader_cmd_start
[02:30:47.058] denso02_bootloader_cmd_start
[02:30:48.260] denso02_bootloader_cmd_start
[02:30:49.462] denso02_bootloader_cmd_start
[02:30:50.664] denso02_bootloader_cmd_start
[02:30:51.084] kernel get version
[02:31:09.591] ssm2_init
[02:31:09.761] ECU ID is 3D FFFFFFA4 58 30 05
[02:31:09.761] ssm2_cmd_0x81
[02:42:43.899] Version 1.29.906
[02:42:43.909] 8 memory models read.
[02:42:46.162] 140 ROM metadata models read.
[02:42:46.162] checksum module "subarudbw" loaded.
[02:42:46.162] flashing tool "wrx02" loaded.
[02:42:46.162] flashing tool "wrx04" loaded.
[02:42:46.162] flashing tool "sti04" loaded.
[02:42:46.162] flashing tool "sti05" loaded.
[02:42:46.162] flashing tool "mitsukernel" loaded.
[02:42:46.162] flashing tool "mitsukernelocp" loaded.
[02:42:46.162] flashing tool "mitsubootloader" loaded.
[02:43:20.382] ssm2_init
[02:43:20.552] ECU ID is 3D FFFFFFA4 58 30 05
[02:43:20.552] ssm2_cmd_0x81
[02:43:37.026] denso02_bootloader_cmd_start
[02:43:38.227] denso02_bootloader_cmd_start
[02:43:39.429] denso02_bootloader_cmd_start
[02:43:40.631] denso02_bootloader_cmd_start
[02:43:41.833] denso02_bootloader_cmd_start
[02:43:42.273] kernel get version
[02:43:53.579] denso02_bootloader_cmd_start
[02:43:54.781] denso02_bootloader_cmd_start
[02:43:55.983] denso02_bootloader_cmd_start
[02:43:57.185] denso02_bootloader_cmd_start
[02:43:58.386] denso02_bootloader_cmd_start
[02:43:58.807] kernel get version
[02:44:12.797] ssm2_init
[02:44:12.957] ECU ID is 3D FFFFFFA4 58 30 05
[02:44:12.967] ssm2_cmd_0x81
[02:44:27.759] ssm2_init
[02:44:27.919] ECU ID is 3D FFFFFFA4 58 30 05
[02:44:27.929] ssm2_cmd_0x81
[02:44:39.776] ssm2_init
[02:44:39.936] ECU ID is 3D FFFFFFA4 58 30 05
[02:44:39.946] ssm2_cmd_0x81
[02:44:54.527] ssm2_init
[02:44:54.687] ECU ID is 3D FFFFFFA4 58 30 05
[02:44:54.697] ssm2_cmd_0x81
maybe this isnt for me? should i go ahead and buy UTEC?
wrx_aruba
Postby wrx_aruba » Thu Dec 14, 2006 4:49 am
bump for help?
wrx_aruba
Postby Twinturbo » Thu Dec 14, 2006 5:02 am
Yes, you need the white connector...
On 06- you only need to connect the green ones.
Twinturbo
Postby wrx_aruba » Thu Dec 14, 2006 6:35 am
OK,
a friend of mine who probally has the same ECU as mine was able to read his rom without the white flash connectors!
how can that be?
can someone give me tips on how to connect?
or if i should connect the white connectors should the car stop from going into diagnoses mode?
thanks
wrx_aruba
Postby Blindstuff » Thu Dec 14, 2006 7:26 am
Just connect the white connectors, I didnt need them as far as I remember, but it wont harm to give it a try.
Blindstuff
Postby wrx_aruba » Thu Dec 14, 2006 10:09 am
thanks, i will try the white connectors
should it stop the car from diagnoses
wrx_aruba
Postby bb8 » Wed Jan 10, 2007 10:22 am
bb8
Postby cboles » Wed Jan 10, 2007 2:41 pm
I know that with some JDM cars you need to push the clutch pedal in as well to initiate boot loading mode. Can you try holding the clutch pedal in while EcuFlash tries to connect?
Postby wrx_aruba » Thu Aug 14, 2008 11:13 am
Yes,
My car is now XPT Stage2....
What i think happend to me was my car had a very weak battery and it wasnt allowing me to read, good thing it didnt, i would be bad if i was reading my rom and the battery died...
Like i said before if a user need help reading his rom i can advice him how to do so... iam like a pro now have read like 5 others roms of different wrx's
Iam glad i didnt give up... it took me about a year to try again with a new battery and new laptop...
Cheers,
wrx_aruba
Users browsing this forum: No registered users and 33 guests
