JECS ROM Download
Postby west_minist » Thu Mar 16, 2006 4:59 pm
That is very much true.
Postby NoCtrl » Sun Mar 19, 2006 1:39 pm
west_minist wrote:I opened up my JDM MY00 Impreza non-turbo Unisia JECS ecu today.
UNISIA JECS CORPORATION
A5
22611 AE463
A18-000 D3G 0524
On the broad:-
A19-001 D52N
The large chip w/ many legs:
UJ
WA12212920WWW
016E100
Forester S-turbo -99 (SF5, EU model):
Picture of ECU inside
ECU cover:
F4
22611 AE900
A18-000 DQ5 8 804
PCB: A19-001 DS2N
CPU:
WA12212920WWW
823D107
Two very different cars, but the CPU chip seems to be the same.
Im guessing that the circuit boards are equal too (with different IO components in place to control AVCS, turbo and the like)
Would be very cool if others with JECS ECU could post pictures!
NoCtrl
Postby west_minist » Sun Mar 19, 2006 2:31 pm
My broad looks the same w/ the same sockets w/ one N/A.
What model SF5 is this? 2.0L, 2.5L or 2.0 Turbo?
Do you have avcs?
I need to identify where the avcs fits in sometime soon, including other pins there that are not shown in the diagram to my model - maybe for Hydra swapping purposes.
Postby NoCtrl » Sun Mar 19, 2006 3:58 pm
Nope, no AVCS on mine..
AVCS is not mentioned at all in the docs I got..
..but these docs are Forester spesific upto -04.
To save space and reduce duplicate files information for
further engines is located in the Impreza section of this
disc.
..and the Impreza section is not there of course :roll:
I wonder what docs a complete disc contains..
NoCtrl
Postby NoCtrl » Sun Mar 19, 2006 4:04 pm
west_minist wrote:What model SF5 is this? 2.0L, 2.5L or 2.0 Turbo?
Its a 2.0 turbo. EJ205 engine.
NoCtrl
Postby west_minist » Sun Mar 19, 2006 4:24 pm
I did some research and there state under 200hp. Is that correct?
Postby west_minist » Sun Mar 19, 2006 4:27 pm
Out of curiousity, is there such a thing as turbo ecu.
Is it possible if these ecu's when hook up for turbo, use maps w/ internal to addition na modes?
Postby NoCtrl » Sun Mar 19, 2006 5:15 pm
west_minist wrote:I did some research and there state under 200hp. Is that correct?
Yes, 170hp.
As far as i know the only difference between Impreza and Forester (2.0 turbo) engines are Foresters smaller turbos and different cams.
The Forester turbo comes in before 2000 rpms...
Its not a racer, but has other good features 8)
west_minist wrote:Out of curiousity, is there such a thing as turbo ecu.
NAs and turbos does not have the same ECUs.. Different IO components and programming.. same thing goes for AVCS I guess.
NoCtrl
Postby west_minist » Sun Mar 19, 2006 5:17 pm
The torque comes in very good for climbing and lo gear.
Postby NoCtrl » Sun Mar 19, 2006 5:30 pm
west_minist wrote:The torque comes in very good for climbing and lo gear.
Yes, Im hunting for more low rpm torque 8)
NoCtrl
Postby west_minist » Sun Mar 19, 2006 5:32 pm
A smaller turbo, or anti lag w/ a bigger turbo or gearing with a bigger turbo.
Postby STi6 » Thu Mar 23, 2006 1:11 am
Here is a MY99/00 rom file for those interested in hacking away at it. Its from a UK P1
ag340enc.bin
(128 KiB) Downloaded 1377 times
STi6
Postby cboles » Thu Mar 23, 2006 1:18 am
...that file is encrypted :(
Postby STi6 » Thu Mar 23, 2006 3:24 am
damn, thats an ECUT*k file. So the buggers encrypt their files.
STi6
Postby xswrex » Thu Mar 23, 2006 6:00 am
you can try this, who knows it might not be encrypted
test.zip
(70.46 KiB) Downloaded 881 times
xswrex
