EVO5/6 MH7201F - MH7202F read/flash tool - it works.
Postby red^shark » Wed Aug 16, 2006 4:40 am
Hello?.. is this thing on? 8)
So what is that we need to do to modify the code (xml table?) and/or hardware to make this work?
Cboles posted the 1.3m schematics (as requested) a while ago and we havent seen anything more from YP.
Is this just a case of a change in jumper wire to initiate the boot strap load?
Or do we/me need to run IDA to figure out where to go?
EvoScan works fine on my 98 Talon TSi AWD and the 98 has both ports,
the OBDII and the flash initiator port (both plugs connect on the OpenPort 1.3m cable).
The EVO 5/6 and 2g dsm's are currently not supported by the EcuFlash software,
but are listed as under development. Tho I think that as far as the 2g dsm's go, only the 98 & 99 will work.
Red
98 Talon TSi AWD
91 Talon TSi AWD
90 Galant GSX
red^shark
Postby cboles » Wed Aug 16, 2006 12:55 pm
I have a H8 kernel that is almost done. I'm just totally bogged down in other work. Hopefully I'll get it out in Sept....
Postby 05GarnetLGT » Wed Aug 16, 2006 9:16 pm
this is making me want to buy another DSM :twisted:
05GarnetLGT
Postby RanEvo » Thu Aug 17, 2006 2:22 am
So, it will work on the Mitsubishi Outlander (Turbo), whit the MH8202F ?
cboles wrote:I have a H8 kernel that is almost done. I'm just totally bogged down in other work. Hopefully I'll get it out in Sept....
RanEvo
Postby thefranchise » Fri Aug 18, 2006 4:25 pm
woohoo us 3G Eclipse guys with 2000 ECUs are dyin for this release!!!!
thefranchise
Postby 05GarnetLGT » Mon Aug 21, 2006 11:01 am
red^shark wrote:Hello?.. is this thing on? 8)
Red
98 Talon TSi AWD
91 Talon TSi AWD
90 Galant GSX
are you certain about the 98 and 99 thing? I'm serious about getting another DSM, I loved my talon, but 98s and 99s appear to be ludicrously overpriced.
05GarnetLGT
Postby red^shark » Mon Aug 21, 2006 1:32 pm
I am certain the Evoscan works with my 98 Talon with no cabling mods.
Based on datasheets that I have read, I think the 98 & 99 DSM's will accept a flash based on the h8/500 kernal.
I also know that both connectors on the openport 1.3m cable plug into my 98 talon just fine (it appears to have the proper connectors) and I got an h8/500 error when i tried to use Ecuflash.
We wont know for certain about EcuFlash until sometime in September when cboles gets the h8/500 kernal flash code completed.
And yes it is driving me crazy like a kid waiting for xmas. 8)
Not knowing if i will get what i want or not :cry:
Red
red^shark
Postby 05GarnetLGT » Mon Aug 21, 2006 2:31 pm
I'm already pricing GS-Ts and talon front bumpers.
I think I am gonna build a talipse spyder if this goes through.
05GarnetLGT
Postby RanEvo » Sun Aug 27, 2006 3:13 pm
RanEvo wrote:So, it will work on the Mitsubishi Outlander (Turbo), whit the MH8202F ?
RanEvo
Postby red^shark » Sun Aug 27, 2006 5:17 pm
Is it mid september? :roll:
:roll: :roll: :roll: :roll:
I didnt think so.. :D
I am patiently waiting as well 8)
red^shark
Postby thefranchise » Wed Aug 30, 2006 9:16 am
i'd do anything for september to show up with H8 support :shock:
thefranchise
Postby Sanctifier » Thu Aug 31, 2006 1:33 pm
Waiting patiently until September but still concerned about hardware.
Evo 6 RS2 has no initialization plug near the OBDII socket.
Do I need any other hardware changes to support Colby's new software?
Sanctifier
Postby thefranchise » Tue Sep 05, 2006 11:34 am
mmm september is here??? ;)
thefranchise
Postby Sanctifier » Tue Sep 05, 2006 4:24 pm
thefranchise wrote:mmm september is here??? ;)
Yup but Colby did say he was swamped with work. September has just begun.
Let's hope the revision can also address the lack of the initialization plug in the Evo 5-6.
Sanctifier
Postby red^shark » Tue Sep 05, 2006 4:41 pm
May i suggest you read some of the h8/500 pdf's in the download section?
And then pull your ecu and check to see what model processor is in your ecu.
Red
red^shark
