There is a bug in ECUFlash that causes the program to crash when you use a removable drive (e.g. USB stick) for reading and writing the ROM files.
When you start ECUFlash it's ok, but then when you click "Open" it gives you an error and crashes.
Note that this only happens when you previously saved a ROM to the removable drive, then clicked "Open" WITHOUT the removable drive plugged in.
I think the behaviour should be changed to select the C: if the last used drive (removable or not) could not be accessed.
B.
