07 STi
Postby Keener2.5 » Wed Oct 18, 2006 3:38 pm
So can anyone send me a reflash that eliminates the smog pump code for me?
Thanks,
Brian
Keener2.5
Postby zigzagzok » Sun Oct 22, 2006 8:20 am
hey guys any advice for this link below
am having similar issues :(
am driving a '06 JDM 2.0 LGT SpecB 6MT
http://forums.openecu.org/viewtopic.php?t=1115
zigzagzok
Postby merchgod » Sun Oct 22, 2006 8:51 am
Keener2.5 wrote:So can anyone send me a reflash that eliminates the smog pump code for me?
Thanks,
Brian
Which code(s) are getting? There's more than one for the air pump.
merchgod
Postby Keener2.5 » Sun Oct 22, 2006 9:32 am
Thanks,
Brian
I'll read the code today and post them up. :)
Keener2.5
Postby Keener2.5 » Sat Oct 28, 2006 7:43 pm
I'm using the EcuExplorer software to read the code, but the doesn't have secondary airpump. Can I update the software to read that code?
Keener2.5
Postby merchgod » Sat Oct 28, 2006 7:59 pm
There's more than one airpump code - like 15+.
merchgod
Postby Keener2.5 » Sat Oct 28, 2006 8:05 pm
merchgod wrote:There's more than one airpump code - like 15+.
Oh damn, well mine should be a circuit low for the secondary air pump, but I don't have the actual scan tool here so I can see exactly whats its throwing. :?
edit: Is there anywhere that lists all of them, so I can update the software with all of them?
Edit2: I found them, seems like there are 19 of them.
P0400
Exhaust Gas Recirculation Flow Malfunction
P0401
Exhaust Gas Recirculation Flow Insufficient Detected
P0402
Exhaust Gas Recirculation Flow Excessive Detected
P0403
Exhaust Gas Recirculation Circuit Malfunction
P0404
Exhaust Gas Recirculation Circuit Range/Performance
P0405
Exhaust Gas Recirculation Sensor A Circuit Low
P0406
Exhaust Gas Recirculation Sensor A Circuit High
P0407
Exhaust Gas Recirculation Sensor B Circuit Low
P0408
Exhaust Gas Recirculation Sensor B Circuit High
P0410
Secondary Air Injection System Malfunction
P0411
Secondary Air Injection System Incorrect Flow Detected
P0412
Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413
Secondary Air Injection System Switching Valve A Circuit Open
P0414
Secondary Air Injection System Switching Valve A Circuit Shorted
P0415
Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416
Secondary Air Injection System Switching Valve B Circuit Open
P0417
Secondary Air Injection System Switching Valve B Circuit Shorted
P0418
Secondary Air Injection System Relay "A" Circuit Malfunction
P0419
Secondary Air Injection System Relay "B" Circuit Malfunction
Keener2.5
Postby merchgod » Sun Oct 29, 2006 7:47 am
Here's a definition file for Enginuity for all the CELs on your rom. To use, make sure you have the latest version of Enginuity. Go to the Edit menu and select 'Ecu Definition Manager'. Click on 'Add' and add this definition file.
This includes all CELs. Some CELs are already disabled by Subaru from the factory. To disable a CEL make sure its 'Enable' box is unchecked.
merchgod
Postby Keener2.5 » Sun Oct 29, 2006 4:07 pm
Thanks! I unchecked all the secondary air pump codes, so all I need to do now is reflash the ECU using ECU Flash correct?
I know I shouldn't be nervous about flashing my ECU, I've done it to a bunch of other cars, but since there is just about no way to find a replacement... :lol:
Keener2.5
Postby merchgod » Sun Oct 29, 2006 4:10 pm
Yep, that's it.
merchgod
Postby Keener2.5 » Sun Oct 29, 2006 4:42 pm
merchgod wrote:Yep, that's it.
So I reflashed it. It fired up, however, It idles at 1500, dbw is on a super delay, and even then only kicks up the rpms a few. All in all in doesn't sound happy. :(
EDIT: Well, after I flashed it back to stock and unplugged the obd2 port from the laptop, and it went back to normal. Everything seems cool now. I'm going to flash it again and see what happens.
EDIT:2 Well its doing the same thing. Going to flash back to stock again.d
Keener2.5
Postby akcel » Sun Oct 29, 2006 7:40 pm
ami crazy or did brian just post 3 times in one post? hahah splite personallity syndrome?
akcel
Postby Keener2.5 » Sun Oct 29, 2006 7:55 pm
Heres the ROM that I made where the codes are turned off.
Keener07STinocodes.hex
(1 MiB) Downloaded 704 times
Keener2.5
Postby merchgod » Sun Oct 29, 2006 8:16 pm
I forgot to put the checksum fix in there. That is why you are getting that. Here's the definition file with the checksum fix added. Remove the old defintiion and add this definition in the definition manager. Open the rom and then click enable on the checksum fix. Then save and flash.
If the checksum fix is not applied is goes into a limp home mode whenever you make changes to the rom. After you apply to fix, you won't have to worry about it again.
merchgod
Postby Keener2.5 » Sun Oct 29, 2006 8:55 pm
w00t!! No cels! Thank You so much I can tell you how excited I am to get rid of them, next step, maybe smog it. :lol:
Keener2.5
