ALS on Stock ECU
ALS on Stock ECU
Postby evo400 » Thu Jul 06, 2006 11:45 am
I noticed that the stock ECU on my GSR has ALS function, and this feature can be modified with openecu only by RPM (stock value 2500RPM). How can i setup for more powerfull ALS ? Is there some way to set it for launchcontrol, for more boost at launch ?
evo400
Postby dudical26 » Tue Jul 11, 2006 8:12 am
It is non-functional.
dudical26
Postby evo400 » Tue Jul 11, 2006 12:22 pm
dudical26 wrote:It is non-functional.
Do you know more about? I think the stock ecu is realy doing something like ALS while decelerating short, because sometimes are going flames from my exhaust :D
evo400
Postby nvr2fast » Tue Jul 11, 2006 4:24 pm
What are you modifying to enable Anti Lag System? I did not think the stock ECU had this capability built in without making changes to the hardware?
The flames coming out should simply be an over rich situation, not ALS.
nvr2fast
