bofh wrote:I will be putting a switch on my pin 11. That way, I can get dual use out of it with other cars.
But to the other poster, are you sure your 95 Legacy is full ODB-II? I thought it was only 96 and up, and pre 96 was ODB-I, or a odd hybrid.
3) Using the OBD-II general scan tool, call up diagnostic
trouble code(s) and freeze frame data.
OBD-II general scan tool functions consist of:
(1) MODE $01: Current powertrain diagnostic data
(2) MODE $02: Powertrain freeze frame data
(3) MODE $03: Emission-related powertrain diagnostic
trouble codes
(4) MODE $04: Clear/Reset emission-related diagnostic
information
(5) MODE $05: Oxygen sensor monitoring test results
Read out data according to repair procedures.
(For detailed operation procedures, refer to the OBD-II
General Scan Tool Operation Manual.)
NOTE:
For details concerning diagnostic trouble codes, refer to
the DIAGNOSTIC TROUBLE CODE (DTC) LIST .bofh wrote:Last thing. Is there some reason you need to use the e-commerce site? Is there any way I can just call you up, and send a check? Or is KGreb ordering one? Can he get two, and I'll just get it from him?
Spiider wrote:I tried about 4 times to order one and I think the creditcard system is not working properly.
Can I paypal or something?
yarikoptic wrote:uploaded image (from the same 1995 manual) says that pin 11 is not loaded... so hopefully it is so... the last check - is check under dash board if really 11 is not loaded
cboles wrote:Are you able to do SSM on the K-line of your vehicle, or only OBD2 stuff?
