There is a huge discrepancy between the Bar and PSI readings in the definition files which does not correspond to the actual conversion of bar to PSI.
For instance if I open my stock rom, A4TJ11C, with the Standard Defs file I get a target boost of 18.56 PSI (which it should be after conversion to PSI) This should equate to 1.28 Bar.
However if I open that same ROM with the Metric definitions the target boost reads 2.93 Bar or 33.2 PSI!!!
That is no where near an acceptable margin of error. *.56.....that is a ludicrous engine blowing, turbo frying discrepancy.
So how do I know what value is being uploaded to my ECU?
And why would what should be a simple multiplication problem be so off?
