Yesterday I was attempting to flash some tweaks I made to my map on my stg2 tune. Previously once I got the voltage too high error and was able to flash by turning the lights on. I am getting the same error. I have tried flashing probably 30-40 times now, going back to stock, the original stg2 map, and the latest one. Every time I am getting the voltage too high error. It does not say the voltage just that it is too high. Finally I had to give up and turn off the ignition.
I tried running every accessory in the car, radio all the way up, high beams on, defroster. Everything. Still the same damn error over and over. Starting to get SUPER pissed because it used to work fine. What could have happened?
I understand the ECU is possibly bricked now because I had to turn it off. I had no choice I did everything possible. I am now deleting and reinstalling the software on my laptop. Any help would be much appreciated.
A4sgc00c
memory model 68HC16Y5
kernel error: programming voltage is too high
failed to commit flash at (sometimes it is in the 00020000 range sometimes in the 00010000 range)
Test write is perfect every time. Then when I go to write it fails every time. Don't know what to do and my car is useless until I can fix this. Thanks for the help
