Diesel engine
Diesel engine
Postby Frenzy » Sat Apr 18, 2009 3:57 am
Hi ,
Are we able to tune legacy , forester and subaru diesel ?
Frenzy
Re: Diesel engine
Postby christian_piasini » Sat Apr 18, 2009 7:07 am
YES, can tune it,
but not yet with Tatrix 2.0
Best regards
R&D Piasiniengienering
Re: Diesel engine
Postby Frenzy » Sat Apr 18, 2009 7:48 am
And with the 1.3 ?
Can we acces to ecu rom ?
Frenzy
Re: Diesel engine
Postby Yuregir » Sun May 24, 2009 5:15 am
If im not wrong, EDM diesel models are using Bocsh Edc ecu you can read write with Byteshooter unit but ecuflash/romraider doest have that support.
You can tune it with WinOLS Licenced version
Regards
Yuregir
Yuregir
Re: Diesel engine
Postby christian_piasini » Wed May 27, 2009 9:23 am
The Subarus Diesel have Denso ecu, not bosch.
and right now Serial suite Piasinienginenring and ECUtek are the only ones device support them.
Best regards
R&D Piasiniengeering
Re: Diesel engine
Postby Jochen_145 » Mon Nov 23, 2009 5:43 am
Hei,
I heart some rumors, that there´s worked on Tratrix 2.0 doing the Denso ECUs ?
What´s actual state ?
It it true ?
Will there be a a solution with openecu-software for diagnostic, read and flash the Diesel-ECU someday ?
Mazda works with the same ECU, so are there any hinds for deffinitions of maps ?
May I can go for finding interesseting maps, while waiting for a functional flash soltuion
Regrads
Jochen_145
Re: Diesel engine
Postby christian_piasini » Wed Nov 25, 2009 8:46 am
Hope you already know, that rumor have a lot, and true things much less.-... ;-)
Best regards
CHristian Piasini
R&D Piasineingineering
Re: Diesel engine
Postby remapping » Thu May 13, 2010 11:17 pm
Not sure about the Mazda's, but there is another tool being developed to work with Subaru / Mitsubishi diesels.
IMHO, the time will come for Tactrix to develop support for Boxer diesel, too.
remapping
Re: Diesel engine
Postby Jochen_145 » Thu Jun 03, 2010 7:52 am
remapping wrote:but there is another tool being developed to work with Subaru / Mitsubishi diesels.
Christians tool does it and ECKtek is also able to.
If I look at ECUtek-SW optically it is very similar to ECUFlash, so maybe there are some hints to implementate the Diesel-ECU to ECUFlash.
I also hear that ECUedit should work at flashing Diesel-ECU, but this is at this time also just an other roumors..
Maybe you can give us a hint (or me via PN) with tool do you mean ?!
On request at Tactrix, not in the near future :(
AFAIK the Diesel-Engines are not offert in the US, so there is no need to implementat then on a US-tool.
Hopefully I´m wrong with this...
Jochen_145
