Is ecuflash compatible with the older tatrix cables? Everytime I try to connect to the ECU with the tatrix cable and ecuflash, all I get is "no vehicle interface" in the bottom corner.
The other software I use has no trouble communicating with the ECU: ecuexplorer, romraider logger, enginuity.
I've upgraded to winxp SP3 to try to solve the problem.
I've tried uninstalling the FTDI drivers.
I've tried uninstalling and reinstalling ecuflash.
Any tips or suggestions? Any other software to do the reflash?
All I'm trying to do is disable the P0420 DTC so I can attempt to pass my emissions test.
Thanks!
Walter
