Reflashed A4SE900D (531)
Postby Xmicho » Thu Jan 05, 2006 3:16 am
Just an image of my first reflash. IAM is doing fine at 16. Knock correction seems ok. Boost has gone up to 1.04 bar from 0.95 bar. 40kmh - 120kmh time in 3rd gear has dropped by 1.5 seconds from stock. I am now desperately searching for locations and conversion factors for
1. Boost Limit
2 Turbo Dynamics (Continuous)
3 Turbo Dynamics (Burst)
If anyone can help find the locations for these, I'd be more than grateful.
Chris
Xmicho
Re: Reflashed A4SE900D (531)
Postby crispyduck » Sat Jan 07, 2006 1:28 pm
Xmicho wrote:Just an image of my first reflash.
Did you mean to upload your image here? If so, it's not here!
Postby Xmicho » Sun Jan 08, 2006 6:37 pm
Yes I did mean to. And I'm pretty sure I filled in the attachment filename and comment. Didn't realise it didn't appear. Let me try again...
Oh, ok. .csv and .hex file extensions are not allowed. Any idea how I get around this so that I can post logs and rom images?
Xmicho
Postby Xmicho » Sun Jan 08, 2006 6:50 pm
Eureka! Here you go.
mod_6_060104.zip
The image I flashed to get this log.
(84.12 KiB) Downloaded 495 times
ecuExplorer [AF531] 04-01-2006 02h04m09s.zip
Log, after reflash. 3rd gear WOT
(86.38 KiB) Downloaded 391 times
Xmicho
Postby venom79 » Thu Aug 31, 2006 11:51 pm
I reflashed that rom in my -01 eu bugeye (AH700D) Boost went up to 1.23 bar.. I´m wondering why boost is 1.04 bar in your car..?
venom79
Postby Xmicho » Thu Aug 31, 2006 11:59 pm
Dude, that was in January. Now I'm pulling over 1.4 bar up to 5500rpm. Wondering whether to take the next step and go 1.55bar. I'm just looking for confirmation that the td04hl-13t can flow over 400cfm before I do it.
Xmicho
Postby venom79 » Fri Sep 01, 2006 12:49 am
No no, i mean why the same map that you have attached above gives me 1.23 bar and you 1.04 bar..
venom79
Postby Xmicho » Fri Sep 01, 2006 12:54 am
Not sure about that, probably different set ups e.g. exhaust, intake etc.
Xmicho
Postby Viz » Fri Feb 02, 2007 2:04 pm
Xmicho,
Interested in flashing this - but before I do what mods do you have on your car ?
Viz
Postby Xmicho » Sun Feb 04, 2007 4:43 pm
Hi, mods on my car are very basic. Removed up-pipe cat and first of the two downpipe cats, remus muffler and that's all. I realise why somw people had been getting 1.23 bar with this map while mine was only hitting 1.04 bar previously. It was the boost control solenoid. Once I'd changed over to a Perrin EBCS, boost figures really jumped and spool up was much quicker. Good luck to ya.
Chris
Xmicho
Postby 02wrx » Tue Feb 20, 2007 1:01 pm
what year is your car and is it sti or non sti and what program do i need to flash this to my car.im getting a vag com cabel in a coupledays. im new to this and dont wana pay 750+ to get my ecu flashed lol ne tips or hints would be great. my mods are gp moto headers, catback exhaust, cold air intake, rs bov,mbc street light flywheel,.. thanks
02wrx
Postby mafia69 » Thu Aug 02, 2007 6:01 am
Xmicho wrote:Dude, that was in January. Now I'm pulling over 1.4 bar up to 5500rpm. Wondering whether to take the next step and go 1.55bar. I'm just looking for confirmation that the td04hl-13t can flow over 400cfm before I do it.
What kind of setup you are using at the moment? I'm interested because you are using such a high boost and i would like to know what to tweak if i go past 1.2 bar. Thanks! Any chance of seeing peek of your map?
mafia69
Postby Xmicho » Fri Dec 21, 2007 9:23 pm
Sorry for the late post. Here's what I can tell you, I've kept peak boost at 1.4bar but only up to 5400rpm after which the stock turbine blades will start to go supersonic and disintegrate. You have to keep your total flow below max flow of the turbo. I had a PC crash a while ago so I've lost most of my sources but you can find a compressor map for the TD04HL online and a cfm calculator for boost vs capacity vs RPM. Use this to plan your boost so that it does not exceed the safe limits on the compressor map. If I remember corectly, the stock turbo can support 1.4bar on a 2.0L motor up to 5500rpm. The only mod I did after the ones listed here are a Perrin EBCS (stock solenoid was unreliable) and a Remus muffler. Wish I could tell you more. Good luck.
Xmicho
