I am seeing all of these 05 Airtrek ROMs and they were pulled using EVO 9 read method, but all are EXACTLY like the 02-03 Airtreks that I have looked at (except for the HEX size). Even the ID Tags.
Did Mitsubishi keep the data the same for this particular model over the years? Should I apply the EVO 9 base or are the people that are pulling the ROMs not choosing the correct read method? I almost feel as though that the ECU did not change that much if the data is the same. On the other hand though, if they can only pull a ROM using the EVO 9 read method, I should logically use that flash method.
The major issue that is happening is that when I build an XML for the 05, it over-writes the XMLs of the 02-03 (depending on model ROM) because the ROMs have the same internal HEX address. It happens both ways, so as I would define one the other was overwritten, LIKE 5 TIMES. This is why I have not touched them to much.
I want to give the people that pulled the ROMs the benefit of the doubt that they are giving me the correct years, but the same HEX/XML addresses for the 03 as the 05?
Lend me your thoughts guys.
