Unable to log LC-1 via standalone logger
Hi guys,
Having a problem logging my LC-1 with the standalone logging function on the tactrix dongle. In the logs under inno.afr and inno.lambda it just shows all 0's.
Setup:
- Terminator plug in the IN cable
- 2.5mm cable bought from innovate motorsports (male to male): http://www.innovatemotorsports.com/xcar ... 271&page=1
- Also tried another random 2.5mm cable that I found and that produced the same 0's in the log.
I can log the LC-1 just fine using EvoScan and Logworks using the serial cable and my laptop, but can't get it working on the standalone logger. Both Evoscan and Logworks display exactly what appears on my gauge at any given time.
Thanks for any help you guys can provide.
- Attached a zip file with my config and a log file
Edit: For some reason it won't allow my to upload any file, I'll paste my config file:
And a log file:
Setup:
- Code: Select all
; uncomment the line below to minimize the information written to logcfg.out
; this will greatly decrease the startup time to begin logging if you already
; have a working logcfg.txt without any problems
debug=noout
; sample logging configuration file for openport 2.0
; must be named logcfg.txt and be placed in the root directory of the
; microSD card inserted in the openport in order to work
; this sample logs using the KWP2000 ReadMemoryAddress command over the ISO15765, which works
; for CAN based mitsubishis that have had their ROMs modified to allow the use of this command.
; this command is also known as "mode23" on some forums. since this command reads directly from
; ECU memory, the paramid addresses used are different for different ROM versions. the following
; example is for the USDM EVO X ROMs in the 526800xx series.
;----------------mrmacan evox----------------
; log channel settings
type=mrmacan
;-------------parameters-------------
paramname=RPM
paramid=0x80875C
databits=16
scalingrpn=x,3.90625,*
paramname=Load
paramid=0x808784
databits=16
scalingrpn=x,0.3125,*
;paramname=LoadMivecTiming
;paramid=0x80878A
;databits=16
;scalingrpn=x,0.3125,*
paramname=Timing
paramid=0x808A1F
scalingrpn=x,20,-
paramname=Barometer
paramid=0x80AA4D
scalingrpn=x,0.07252,*
paramname=Boost
paramid=0x80872e
databits=16
scalingrpn=x,0.0483675,*,14.5,-
paramname=BWGDC_IAT_Adjust
paramid=0x805180
databits=16
scalingrpn=x,128,-,2,/
paramname=AtmosBoostBase
paramid=0x8051a0
databits=16
scalingrpn=x,0.19347,*
paramname=Knock
paramid=0x808A63
paramname=AFRMap
paramid=0x80890D
scalingrpn=1881.6,x,/
;paramname=AccelPedalPosition
;paramid=0x8095FD
;scalingrpn=x,32,-,0.5059,*
paramname=TPS
paramid=0x80870D
scalingrpn=x,0.392157,*
;This one shows a Max of 100% instead of the common 87 degree one (above)
;paramname=TPS
;paramid=0x80870d
;scalingrpn=x,32,-,0.505882,*
paramname=ActiveWGDC
paramid=0x808b6d
scalingrpn=x,0.5,*
paramname=IPW
paramid=0x80aa88
databits=16
scalingrpn=x,0.001,*
paramname=Corr_TimingAdv
paramid=0x8089FF
scalingrpn=x,20,-
paramname=MAT
paramid=0x808672
databits=16
scalingrpn=x,1.8,*,40,-
paramname=ECT
paramid=0x808653
paramname=IAT
paramid=0x80866D
;scalingrpn=x,1.8,*,40,-
;paramname=Speed_mph
;paramid=0x8087ff
;scalingrpn=x,1.243,*
;priority=2
paramname=STFT
paramid=0x8088B0
scalingrpn=x,0.1953125,*,25,-
priority=2
paramname=LTFT_Idle
paramid=0x804573
priority=2
paramname=LTFT_Cruise
paramid=0x804575
priority=2
paramname=LTFT_In_Use
paramid=0x8088C1
priority=2
paramname=WGDC_Correction
paramid=0x808783
scalingrpn=x,0.5,*,64,-
paramname=Load_Error
paramid=0x80870F
scalingrpn=x,0.15625,*,20,-
;paramname=Front_O2
;paramid=0x80867D
;scalingrpn=x,0.01952,*
;paramname=Rear_O2
;paramid=0x808681
;paramname=Knock_Voltage
;paramid=0x80872B
;paramname=Battery_Voltage
;paramid=0x808703
;scalingrpn=x,0.07333,*
;paramname=Injector_Latency
;paramid=0x808945
;paramname=InVVT_Target
;paramid=0x809526
;databits=16
;scalingrpn=4096,x,-,0.01953125,*
;paramname=ExVVT_Target
;paramid=0x809532
;databits=16
;paramname=InVVT_Actual
;paramid=0x80955E
;databits=16
;paramname=ExVVT_Actual
;paramid=0x80956A
;databits=16
paramname=MAF_Volts
paramid=0x808F78
databits=16
scalingrpn=x,0.0048828,*
;paramname=MAF_Airflow_gs
;paramid=0x8087f8
;databits=16
;scalingrpn=x,0.02,*
;paramname=PassiveWGDC
;paramid=0x80a653
;scalingrpn=x,0.5,*
;paramname=knock_adc_processed
;paramid=0x808a69
;paramname=knock_base
;paramid=0x80aa7f
;paramname=knock_var
;paramid=0x80aa7b
;paramname=knock_change
;paramid=0x80aa81
;paramname=knock_dynamics
;paramid=0x808a77
;paramname=RearO2AFR
;paramid=0x808681
;databits=16
;scalingrpn=x,0.008671875,*,10,+
;-------------triggers---------------
; note that parameters must be previously defined
; before defining triggers using them
; triggers allow you to control when logging starts and stops
; this example sets up triggers such that logging only occurs
; when the engine is running (RPM > 0)
; triggers consist of some evaluation of the form [trigparam] [condition] [value]
; and a resulting action which is done if the evaluation is true
paramname=CruiseLight
paramid= 0x8045C5
databits=1
offsetbits=5
isvisible=0
priority=2
conditionrpn = CruiseLight,1,==
action = start
conditionrpn = CruiseLight,0,==
action = stop
;Knock Trigger
;conditionrpn = Knock,1,>
;action = start
;conditionrpn = Knock,0,==
;action = stop
;----------------inno----------------
type=inno
; log from an innovate bus via the 3/32" jack
; currently the LC-1 is the only supported device
; in the "inno" case the parameters are already pre-defined, you just
; need to reference them by name so that they are included in the log
; output. note that these parameters won't become valid until the LC-1
; has been calibrated and the sensor is warmed up.
paramname = inno.afr
;paramname = inno.lambda
And a log file:
- Code: Select all
sample time RPM Load Timing Barometer Boost BWGDC_IAT_Adjust AtmosBoostBase Knock AFRMap TPS ActiveWGDC IPW Corr_TimingAdv MAT ECT IAT STFT LTFT_Idle LTFT_Cruise LTFT_In_Use WGDC_Correction Load_Error MAF_Volts inno.afr
0 23.75 828.125 20.625 11 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.016 11 143.6 156.2 92 3.125 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
1 24 816.406 20.9375 11 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.04 11 141.8 156.2 93 2.73438 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44043 0
2 24.25 812.5 20.9375 11 14.7216 -9.51815 0 14.7037 0 14.7 12.1569 0 2.008 11 141.8 156.2 93 2.73438 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44043 0
3 24.5 804.688 20.9375 11 14.7216 -9.51815 0 14.7037 0 14.7 12.1569 0 2.032 10 141.8 156.2 93 2.73438 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.42578 0
4 24.75 808.594 20.9375 10 14.7216 -9.37304 0 14.7037 0 14.7 11.7647 0 2 10 141.8 156.2 92 2.73438 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.43066 0
5 25 796.875 20.9375 11 14.7216 -9.46978 0 14.7037 0 14.7 12.1569 0 2.048 10 141.8 156.2 92 2.73438 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
6 25.25 804.688 20.9375 11 14.7216 -9.51815 0 14.7037 0 14.7 11.7647 0 2.032 10 141.8 156.2 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.43066 0
7 25.5 804.688 20.9375 11 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 156.2 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.43066 0
8 25.75 800.781 20.9375 11 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 156.2 92 2.34375 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
9 26 804.688 21.25 11 14.7216 -9.51815 0 14.7037 0 14.7 12.1569 0 2.04 10 141.8 156.2 92 2.34375 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43066 0
10 26.25 808.594 20.9375 10 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.04 10 141.8 156.2 92 2.34375 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43554 0
11 26.5 800.781 21.25 11 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.072 10 141.8 156.2 92 1.75781 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
12 26.75 812.5 21.25 10 14.7216 -9.51815 0 14.7037 0 14.7 12.1569 0 2.008 10 141.8 156.2 92 1.75781 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
13 27 789.063 21.5625 12 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.032 10 141.8 156.2 92 1.75781 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.42578 0
14 27.25 789.063 21.25 12 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.032 10 141.8 156.2 92 1.75781 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
15 27.5 804.688 21.25 11 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.032 10 141.8 156.2 92 1.75781 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43554 0
16 27.75 804.688 21.25 10 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 156.2 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43066 0
17 28 796.875 21.5625 11 14.7216 -9.22794 0 14.7037 0 14.7 12.1569 0 2.056 10 141.8 156.2 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
18 28.25 796.875 21.5625 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.04 10 141.8 156.2 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
19 28.5 808.594 21.5625 10 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 156.2 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43066 0
20 28.75 804.688 21.5625 11 14.7216 -9.27631 0 14.7037 0 14.7 12.1569 0 2.008 10 141.8 156.2 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
21 29 808.594 21.5625 10 14.7216 -9.27631 0 14.7037 0 14.7 12.1569 0 2.032 10 141.8 156.2 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.45019 0
22 29.25 800.781 21.5625 11 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.016 10 141.8 156.2 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43554 0
23 29.5 796.875 21.875 11 14.7216 -9.22794 0 14.7037 0 14.7 12.1569 0 2.048 10 141.8 156.2 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
24 29.75 808.594 21.5625 10 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.008 10 141.8 156.2 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
25 30 796.875 21.5625 11 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.032 10 141.8 156.2 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43554 0
26 30.25 796.875 21.875 11 14.7216 -9.17957 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 156.2 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
27 30.5 796.875 21.875 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.04 10 141.8 158 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.45019 0
28 30.75 800.781 21.875 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 158 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43554 0
29 31 800.781 21.5625 11 14.7216 -9.17957 0 14.7037 0 14.7 12.1569 0 2.04 10 141.8 158 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
30 31.25 808.594 21.5625 10 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 158 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
31 31.5 800.781 21.875 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.008 10 141.8 158 92 0.195313 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43554 0
32 31.75 785.156 21.875 12 14.7216 -9.13121 0 14.7037 0 14.7 12.1569 0 2.008 10 141.8 158 92 0.195313 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
33 32 804.688 21.875 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.016 10 141.8 158 92 0.195313 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
34 32.25 800.781 21.875 11 14.7216 -9.17957 0 14.7037 0 14.7 12.1569 0 2.048 10 141.8 158 92 0.195313 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43554 0
35 32.5 785.156 22.1875 12 14.7216 -9.17957 0 14.7037 0 14.7 12.1569 0 2.048 10 141.8 158 92 0.195313 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
36 32.75 800.781 21.875 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 158 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
37 33 800.781 21.875 11 14.7216 -9.17957 0 14.7037 0 14.7 12.1569 0 2.04 10 141.8 158 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
38 33.25 804.688 21.875 11 14.7216 -9.13121 0 14.7037 0 14.7 12.1569 0 2.04 10 141.8 158 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.45019 0
39 33.5 804.688 21.875 11 14.7216 -9.22794 0 14.7037 0 14.7 12.1569 0 2.08 11 141.8 158 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.45019 0
40 33.75 828.125 21.5625 11 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.032 11 141.8 158 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
41 34 839.844 21.25 10 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.008 11 141.8 158 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.45019 0
42 34.25 828.125 21.5625 11 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.04 11 141.8 158 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
43 34.5 820.313 21.5625 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.048 11 141.8 158 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43554 0
44 34.75 843.75 20.9375 10 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.032 11 141.8 158 92 1.36719 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
45 35 851.563 20.9375 10 14.7216 -9.46978 0 14.7037 0 14.7 12.1569 0 2.008 11 141.8 158 92 1.36719 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
46 35.25 828.125 21.25 11 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.032 11 141.8 158 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.43554 0
47 35.5 839.844 20.9375 10 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.016 11 141.8 158 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44043 0
48 35.75 832.031 20.9375 11 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.024 11 141.8 158 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44043 0
49 36 824.219 20.9375 11 14.7216 -9.27631 0 14.7037 0 14.7 12.1569 0 2.024 11 141.8 158 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
50 36.25 824.219 20.9375 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 1.992 11 141.8 158 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
51 36.5 812.5 20.9375 11 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.056 10 141.8 158 92 1.75781 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
52 36.75 800.781 21.25 11 14.7216 -9.46978 0 14.7037 0 14.7 12.1569 0 2.008 10 141.8 158 92 1.75781 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43066 0
53 37 796.875 20.9375 11 14.7216 -9.27631 0 14.7037 0 14.7 11.7647 0 2.008 10 141.8 158 92 1.75781 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.43066 0
54 37.25 792.969 20.9375 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.008 10 141.8 158 92 1.75781 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
55 37.5 796.875 21.25 11 14.7216 -9.37304 0 14.7037 0 14.7 11.7647 0 2.008 10 141.8 159.8 92 1.75781 -0.195313 -2.73438 -0.195313 -42 -15.3125 1.42578 0
56 37.75 804.688 20.9375 11 14.7216 -9.27631 0 14.7037 0 14.7 11.7647 0 2 10 141.8 159.8 92 1.36719 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.43554 0
57 38 785.156 21.5625 12 14.7216 -9.37304 0 14.7037 0 14.7 11.7647 0 2.024 10 141.8 159.8 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.3125 1.43066 0
58 38.25 804.688 21.25 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 159.8 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43554 0
59 38.5 804.688 21.5625 11 14.7216 -9.22794 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 159.8 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
60 38.75 808.594 21.5625 10 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 159.8 92 1.36719 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
61 39 796.875 21.5625 11 14.7216 -9.27631 0 14.7037 0 14.7 12.1569 0 2.008 10 141.8 159.8 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43066 0
62 39.25 796.875 21.5625 11 14.7216 -9.17957 0 14.7037 0 14.7 12.1569 0 2.008 10 141.8 159.8 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
63 39.5 789.063 21.5625 12 14.7216 -9.17957 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 159.8 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
64 39.75 800.781 21.5625 11 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.008 10 141.8 159.8 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.43554 0
65 40 804.688 21.5625 11 14.7216 -9.22794 0 14.7037 0 14.7 12.1569 0 2.024 10 141.8 159.8 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.45019 0
66 40.25 804.688 21.5625 11 14.7216 -9.13121 0 14.7037 0 14.7 12.1569 0 2 10 141.8 159.8 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.45507 0
67 40.5 804.688 21.875 10 14.7216 -9.27631 0 14.7037 0 14.7 12.1569 0 2.032 10 141.8 159.8 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
68 40.75 804.688 21.5625 11 14.7216 -9.17957 0 14.7037 0 14.7 12.1569 0 2.016 10 141.8 159.8 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
69 41 804.688 21.875 11 14.7216 -9.08284 0 14.7037 0 14.7 12.1569 0 2.016 10 141.8 159.8 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.45019 0
70 41.25 812.5 21.5625 11 14.7216 -9.22794 0 14.7037 0 14.7 12.1569 0 1.992 11 141.8 159.8 92 0.585938 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
71 41.5 808.594 21.5625 11 14.7216 -9.27631 0 14.7037 0 14.7 12.1569 0 2 10 141.8 159.8 92 0.195313 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
72 41.75 816.406 21.5625 11 14.7216 -9.13121 0 14.7037 0 14.7 12.1569 0 1.984 11 141.8 159.8 92 0.195313 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
73 42 796.875 21.875 11 14.7216 -9.08284 0 14.7037 0 14.7 12.1569 0 2.016 10 141.8 159.8 92 0.195313 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.45019 0
74 42.25 816.406 21.5625 11 14.7216 -9.27631 0 14.7037 0 14.7 12.1569 0 2.024 11 141.8 159.8 92 0.195313 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44531 0
75 42.5 824.219 21.25 11 14.7216 -9.27631 0 14.7037 0 14.7 12.1569 0 2.008 11 141.8 159.8 92 0.195313 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
76 42.75 835.938 21.25 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.024 11 141.8 159.8 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.45019 0
77 43 824.219 21.5625 11 14.7216 -9.17957 0 14.7037 0 14.7 12.1569 0 2.016 11 141.8 159.8 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
78 43.25 832.031 21.25 11 14.7216 -9.22794 0 14.7037 0 14.7 12.1569 0 1.984 11 141.8 159.8 92 0.976563 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
79 43.5 839.844 20.9375 10 14.7216 -9.27631 0 14.7037 0 14.7 12.1569 0 1.992 11 141.8 161.6 92 0.976563 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
80 43.75 843.75 20.9375 10 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 1.992 11 141.8 161.6 92 0.976563 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
81 44 820.313 21.25 11 14.7216 -9.22794 0 14.7037 0 14.7 12.1569 0 2.024 11 141.8 161.6 92 1.95313 -0.195313 -2.73438 -0.195313 -42 -15.1563 1.44043 0
82 44.25 839.844 20.9375 10 14.7216 -9.27631 0 14.7037 0 14.7 12.1569 0 2.016 11 141.8 161.6 92 1.95313 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
83 44.5 835.938 20.9375 10 14.7216 -9.22794 0 14.7037 0 14.7 12.1569 0 2.048 11 141.8 161.6 92 1.95313 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
84 44.75 824.219 20.9375 11 14.7216 -9.22794 0 14.7037 0 14.7 12.1569 0 2.048 11 141.8 161.6 92 1.95313 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
85 45 832.031 20.9375 11 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.032 11 141.8 161.6 92 1.95313 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
86 45.25 832.031 20.625 11 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.072 11 141.8 161.6 92 2.92969 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.45019 0
87 45.5 839.844 20.625 10 14.7216 -9.27631 0 14.7037 0 14.7 12.1569 0 2.04 11 141.8 161.6 92 2.92969 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44531 0
88 45.75 847.656 20.625 10 14.7216 -9.32468 0 14.7037 0 14.7 12.1569 0 2.032 11 141.8 161.6 92 2.92969 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44043 0
89 46 847.656 20.3125 10 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 1.992 11 141.8 161.6 92 2.92969 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44043 0
90 46.25 851.563 20.3125 10 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.008 11 141.8 161.6 92 2.92969 -0.195313 -2.73438 -0.195313 -43.5 -15.1563 1.44043 0
91 46.5 839.844 20.3125 10 14.7216 -9.37304 0 14.7037 0 14.7 12.1569 0 2.008 11 141.8 161.6 92 2.92969 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.43066 0
92 46.75 832.031 20.3125 11 14.7216 -9.42141 0 14.7037 0 14.7 12.1569 0 2.016 11 141.8 161.6 92 2.92969 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.43554 0
93 47 828.125 20.3125 11 14.7216 -9.42141 0 14.7037 0 14.7 11.7647 0 1.984 11 141.8 161.6 92 2.92969 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.44043 0
94 47.25 820.313 20.3125 11 14.7216 -9.46978 0 14.7037 0 14.7 11.7647 0 2 11 140 161.6 92 2.92969 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.44043 0
95 47.5 816.406 20.3125 11 14.7216 -9.46978 0 14.7037 0 14.7 11.7647 0 2 11 141.8 161.6 92 2.92969 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.42578 0
96 47.75 824.219 20.3125 11 14.7216 -9.56651 0 14.7037 0 14.7 11.7647 0 1.984 11 141.8 161.6 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.42578 0
97 48 820.313 20.3125 11 14.7216 -9.46978 0 14.7037 0 14.7 11.7647 0 1.992 11 141.8 161.6 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.42578 0
98 48.25 808.594 20.625 10 14.7216 -9.37304 0 14.7037 0 14.7 11.7647 0 2.024 10 141.8 161.6 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.43554 0
99 48.5 800.781 20.625 11 14.7216 -9.42141 0 14.7037 0 14.7 11.7647 0 1.992 10 141.8 161.6 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.44043 0
100 48.75 804.688 20.625 11 14.7216 -9.46978 0 14.7037 0 14.7 11.7647 0 2.008 10 141.8 161.6 92 2.34375 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.42089 0
101 49 808.594 20.625 10 14.7216 -9.32468 0 14.7037 0 14.7 11.7647 0 1.984 10 141.8 161.6 92 1.95313 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.42578 0
102 49.25 796.875 20.9375 11 14.7216 -9.37304 0 14.7037 0 14.7 11.7647 0 2.016 10 140 161.6 92 1.95313 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.44043 0
103 49.5 804.688 20.9375 11 14.7216 -9.42141 0 14.7037 0 14.7 11.7647 0 2 10 140 161.6 92 1.95313 -0.195313 -2.73438 -0.195313 -43.5 -15.3125 1.42578 0
