Evoscan Evo5 datalog irregular dataloss/poor communication
Postby Arash » Mon Oct 17, 2011 12:56 am
Hi fellow geeks.
Check out this snapshot from the datalog from an Evo5 I logged this morning.
The logging in the first half poor, like pulsating logging. After that, it's nice and clear.
Any ideas of what causes this? It has happened to me one time before, but perhaps about 20 cars in between without issues.
EvoScanDataLog_2011.10.17_10.06.24.csv
Datalog file
(750.35 KiB) Downloaded 1292 times
Snapshot
Arash
Re: Evoscan Evo5 datalog irregular dataloss/poor communicati
Postby Evo4Mad » Sat Nov 26, 2011 3:29 am
open the log file with notepad, you'll probably find that the LogSeconds has reset back to zero half way down the log file.. it has to be sequential else the chart will plot the two data streams on top of each other, looking like a zigzag like that.
split the log file where the LogSeconds resets, and it should be ok. Also use EvoScan v2.8, this should no longer be occuring in the latest versions of EvoScan. if it is still occuring send the csv log to the evoscan support desk.
thanks,
Hamish.
Postby Arash » Tue Dec 06, 2011 12:52 am
Great Hamish.
I'm sure that will do the trick. Love good solid answers. Thanks a lot!
Arash
