Mut-Monitor is still in very early test stages with plenty of little bugs to iron out, so please bear with me.
This application uses the Mitsubishi MUT Protocol for monitoring data from the Vehicles ECU.
It can be used with OBD-II serial cables as well as FTDI based cables via Direct calls or Virtual Com Ports.
Main Changes for Version 1.5 is that Support has been added for the Tactrix OpenPort 2.0 cable.
It is working here with the cable I have, but need it confirmed from others, just in case I missed something!
**Update** confirmed working on EVO6 and EVO X
As usual it can be downloaded from http://www.myrollingroad.com/showthread.php?t=91
Cheers
Sean.
