Evo1-3 pin out for data logger cable
Hi! Anyone of you guys know what ECU pins to use for MMCd data logger cable on an Evo1-3 ECU?
Forums for ECU reverse engineering and modification
http://forums.openecu.org/
MalibuJack wrote:http://mmcdlogger.sourceforge.net/
Does your ECU share the same pins on that connector shown on the site?
AFAIK I thought they all shared the same diagnostic port which should be wired the same way.
