I have been trying to read a 2005 JDM 2500cc Forester without much luck, tried with and without the green test contectors but I can't find a flash block connector with either 3 or 4 pins. I'm using a 2.0 cable tried ver.1.42 1.43 of eciflash.
Heres the log if any one can help.
Regards,
Zakie
PS: The cable works fine on a EVO8
[15:42:47.687] EcuFlash Version 1.43.3150
[15:42:47.687] OS Version Windows XP
[15:42:47.687] Qt Version 4.6.2
[15:42:47.703] 62 memory models read.
[15:42:47.703] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash1.43/rommetadata
[15:42:47.953] 354 ROM metadata models scanned.
[15:42:47.953] checksum module "subarudbw" loaded.
[15:42:47.953] checksum module "mitsucan" loaded.
[15:42:47.953] checksum module "mitsuh8" loaded.
[15:42:47.953] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[15:42:47.953] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[15:42:47.953] flashing tool "wrx02" loaded.
[15:42:47.953] flashing tool "wrx04" loaded.
[15:42:47.953] flashing tool "sti04" loaded.
[15:42:47.953] flashing tool "sti05" loaded.
[15:42:47.953] flashing tool "mitsukernel" loaded.
[15:42:47.953] flashing tool "mitsukernelocp" loaded.
[15:42:47.953] flashing tool "mitsubootloader" loaded.
[15:42:47.953] flashing tool "shbootmode" loaded.
[15:42:47.953] flashing tool "shaudmode" loaded.
[15:42:47.953] flashing tool "subarucan" loaded.
[15:42:47.953] flashing tool "mitsucan" loaded.
[15:42:55.750] J2534 API Version: 04.04
[15:42:55.750] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:42:55.750] Device Firmware Version: 1.11.3137
[15:42:55.750] Device Serial Number: TAKqp9jY
[15:42:59.625] kernel get version
[15:42:59.843] interface close
[15:42:59.875] J2534 API Version: 04.04
[15:42:59.875] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:42:59.890] Device Firmware Version: 1.11.3137
[15:42:59.890] Device Serial Number: TAKqp9jY
[15:43:00.171] VIN read not supported
[15:43:00.281] interface close
[15:43:00.312] J2534 API Version: 04.04
[15:43:00.312] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:43:00.312] Device Firmware Version: 1.11.3137
[15:43:00.312] Device Serial Number: TAKqp9jY
[15:43:00.484] SSM2 init
[15:43:00.625] SSM2 ECU ID is 3B02594216
[15:43:00.718] Requesting Seed...
[15:43:00.765] Sending Key...
[15:43:00.812] interface close
[15:43:00.843] interface close
[15:43:41.453] J2534 API Version: 04.04
[15:43:41.453] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:43:41.453] Device Firmware Version: 1.11.3137
[15:43:41.453] Device Serial Number: TAKqp9jY
[15:43:43.718] kernel get version
[15:43:43.921] interface close
[15:43:43.953] J2534 API Version: 04.04
[15:43:43.968] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:43:43.968] Device Firmware Version: 1.11.3137
[15:43:43.968] Device Serial Number: TAKqp9jY
[15:43:44.265] VIN read not supported
[15:43:44.375] interface close
[15:43:44.406] J2534 API Version: 04.04
[15:43:44.421] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:43:44.421] Device Firmware Version: 1.11.3137
[15:43:44.437] Device Serial Number: TAKqp9jY
[15:43:44.593] SSM2 init
[15:43:44.750] SSM2 ECU ID is 3B02594216
[15:43:44.843] Requesting Seed...
[15:43:44.906] Sending Key...
[15:43:44.953] interface close
[15:43:44.984] interface close
