non-protocol CAN logging with stand-alone-logger
Hey,
I know, stand-alone-logger is able to sniff a CAN-Bus and use protocoll based logging via CAN-bus.
I wounder, if it is possible to log standart (non protocoll) values with the Tactrix-stand-alone logger ?
I found some scrates, where the OP2.0 is use for CAN-bus siffing, but I like to log values direct form CAN bus..
I know boudrate, ID position in ID, factor and offset.
But how to tell stand-alone-logger to log this values?
Is it possible to bend one of the sample to log simple CAN, without OBD, Subaru or what ever protocoll ?
Like to see some sample, if possible
I like to something in a shape of
Maybe some easy lines for Colby to add this functionallity on Interface-Code ?
BR Jochen
- Code: Select all
type = can
baudrate = 500000
paramname = RPM
paramid = 0x280
format = intel
startbit = 0
databits = 16
scalingrpn = x,0.25,*
BR Jochen
