S-A Logging w/ Tactrix, AEM Uego Works! But Log #'s Strange
I FINALLY got stand alone logging to work with my AEM Uego!!! I found a serial --> 2.5mm cable with the correct pinout, and used an adapter and it works great.
BUT, now I'm having other problems. The numbers that are being output are strange. Here is a sample from the first four lines of my log:
WIDEBAND (looks good!)
14.6
14.6
15
14.7
Engine_Speed
1656.75
1696.25
1718.25
1771.75
Engine_Load_(4-Byte)*
1057442158
1057616504
1057761722
1059111454
Knock_Correction_Advance_(IAM_only)*
1091162112
1091162112
1091162112
1091162112
Manifold_Relative_Sea_Level_Pressure_(4-byte)*
21970500
21974300
21980100
22014900
IAM_(4-byte)*
1063256064
1063256064
1063256064
1063256064
Vehicle_Speed
14.9129
15.5343
16.1557
16.1557
Throttle_Opening_Angle
11.3725
11.3725
11.7647
14.902
What the heck is going on here???? Did I miss something? Below is my LogCfg.
;----------------aem----------------
type=ascii
paramname = WIDEBAND
paramid = 1
type=ssmk
paramname = Engine_Speed
paramid = 0x00000E
databits = 16
scalingrpn = x,4,/
paramname = Vehicle_Speed
paramid = 0x000010
databits = 8
scalingrpn = x,0.621371192,*
paramname = Ignition_Total_Timing
paramid = 0x000011
databits = 8
scalingrpn = x,128,-,2,/
paramname = Throttle_Opening_Angle
paramid = 0x000015
databits = 8
scalingrpn = x,100,*,255,/
paramname = Intake_VVT_Advance_Angle_Right
paramid = 0x00003C
databits = 8
scalingrpn = x,50,-
paramname = IAM_(4-byte)*
paramid = 0xFF8550
databits = 32
scalingrpn = x
paramname = Engine_Load_(4-Byte)*
paramid = 0xFFA6AC
databits = 32
scalingrpn = x
paramname = Knock_Correction_Advance_(IAM_only)*
paramid = 0xFFB074
databits = 32
scalingrpn = x
paramname = Manifold_Relative_Sea_Level_Pressure_(4-byte)*
paramid = 0xFFA528
databits = 32
scalingrpn = x,760,-,0.01933677,*
paramname = Gear_(Calculated)*
paramid = 0xFFA8D1
databits = 8
scalingrpn = x
;-------------triggers---------------
paramname = defogger_sw
paramid = 0x64
databits = 1
offsetbits = 5
isvisible = 0
conditionrpn = defogger_sw,1,==
action = start
conditionrpn = defogger_sw,0,==
action = stop
14.6
14.6
15
14.7
Engine_Speed
1656.75
1696.25
1718.25
1771.75
1057442158
1057616504
1057761722
1059111454
1091162112
1091162112
1091162112
1091162112
21970500
21974300
21980100
22014900
IAM_(4-byte)*
1063256064
1063256064
1063256064
1063256064
Vehicle_Speed
14.9129
15.5343
16.1557
16.1557
11.3725
11.3725
11.7647
14.902
type=ascii
paramid = 1
type=ssmk
paramid = 0x00000E
databits = 16
scalingrpn = x,4,/
paramid = 0x000010
databits = 8
paramid = 0x000011
databits = 8
paramid = 0x000015
databits = 8
paramid = 0x00003C
databits = 8
scalingrpn = x,50,-
paramid = 0xFF8550
databits = 32
scalingrpn = x
paramid = 0xFFA6AC
databits = 32
scalingrpn = x
paramid = 0xFFB074
databits = 32
scalingrpn = x
paramid = 0xFFA528
databits = 32
paramid = 0xFFA8D1
databits = 8
scalingrpn = x
paramid = 0x64
databits = 1
offsetbits = 5
isvisible = 0
action = start
action = stop
