I NEED MAP DEFINITIONS!
Postby TheCloser » Tue Sep 12, 2006 5:57 pm
where can i find map definitions to enable me to view and edit my ecu's parameters?? im getting that error message saying:
"the current map description is invalid or incomplete. please edit the map discription to fix the problem and the map will be viewable again"
my car is an 04 evo 8
please help thanx!
T
TheCloser
Postby S54fan » Wed Sep 13, 2006 12:58 am
Usually people post their ROM with this question. See the pattern of others in this and the Evo IX forum. It is likely that most Evo VIII and IX ROMs are fairly well decoded now, and if not the tables are quite easy to find by searching for patterns like ones we do know, or disassembly eg from known tables to find others.
Postby TheCloser » Wed Sep 13, 2006 10:11 am
as you can see...im new to this forum and i need help. so what would you like me to post, exactly?? how do i post my ROM? thanx
T
TheCloser
Postby S54fan » Wed Sep 13, 2006 1:41 pm
When you reply, click add an attachment.
Postby BarryC » Fri Nov 24, 2006 9:53 am
I am totally new to this software so please be gently but I have the very same problem as above
my car is an 03 evo 8 Jap Import
can someone please point me to a how to for Idiots like me at the moment I am only interested in removing my 180kmph speed limiter,
when I downloaded the rom it asked me for a definition and the only thing remotly close to my model was evo 7 base
I know this is frustrating for all you veterans but I am really interested in learning how to do this,
also what is the XML file
EVO8 03 KE 9371.hex
(256 KiB) Downloaded 898 times
BarryC
Postby eiu » Wed Dec 20, 2006 11:07 am
hello what i can do with this? thanks
evo 8 ralliart.hex
(256 KiB) Downloaded 955 times
eiu
Postby eiu » Wed Dec 20, 2006 11:13 am
i don't understand anything... i can read the evo 8 03 KE rom of barryC and cannoy read mine!!! help me please
eiu
Postby S54fan » Wed Dec 20, 2006 12:54 pm
9366005.xml
93660005.xml
(5.34 KiB) Downloaded 995 times
Postby S54fan » Wed Dec 20, 2006 12:55 pm
90550001
90550001.xml
(4.97 KiB) Downloaded 932 times
Postby eiu » Thu Dec 21, 2006 4:23 am
thank you!!!!
:lol:
eiu
Postby turbrodude » Sun May 13, 2007 10:19 am
Can somebody help me with an XML definition for my ecu? My ecu file is attached.
Once I have the XML, I suppose I place it in the directory:
C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\
but then must I remove all the other XML files in that directory so it only reads the new one?
turbrodude_2003_evo8.hex
(256 KiB) Downloaded 800 times
turbrodude
Postby grayw » Sun May 13, 2007 12:49 pm
Try this one.
94170015.xml
(9.17 KiB) Downloaded 849 times
grayw
Postby turbrodude » Sun May 13, 2007 2:38 pm
I can read the file with that XML file (I already had that one I think), but I was under the impression that there was a better XML file out there because some of the parameters don't appear correctly. For example, the intercooler sprayer parameters don't work right. When I click on IC Relay Timer Air Temp, I can only see the first digit of the 3 digit temperture value. There are more parameters like this that I can't read correctly. Got any ideas how to fix this? Others have said that I have the wrong XML definition.
turbrodude
Postby radsdau » Sun May 13, 2007 3:40 pm
S54fan, thanks for your work here. Your contribution to this forum is invaluable.
Postby C6ect.ect » Thu May 17, 2007 12:51 pm
Not sure if this is the route but I'm (blindedly) searching for a way to log 2 byte load/airflow/rpm with my 04 VIII 96420007 ID and need to find what to use as address and decimal equivalent.
96420007 anyone?
C6ect.ect
