any news?????
any news?????
Postby fotis_rs2 » Sun Aug 20, 2006 7:06 pm
is the ecuflash development over?
is it gonna be finally available for the 6?
:cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
fotis_rs2
Postby Sanctifier » Tue Aug 22, 2006 4:13 am
Sorry, I don't have a clue. I'm wondering the same thing myself.
I have my cable and software for over two months... but getting nowhere.
I hope that colby can finish the Evo 6 version soon. :|
Sanctifier
Postby red^shark » Wed Aug 23, 2006 7:16 am
:roll:
http://forums.openecu.org/viewtopic.php ... c&start=15
:D
"IF" I understand correctly... the ecu hardware in some of the 5/6's is the same as a 98/99 dsm.. both h8/500 based ecu's anyways...
If a particular 5/6 doesnt have the proper connectors... you might be able to scavenge the required hardware from a junkyard that has a 98/99 dsm.
Red
red^shark
Postby HOK » Wed Oct 04, 2006 1:49 am
coming soon me thinks...
HOK
Postby Sanctifier » Wed Oct 04, 2006 4:04 am
^ ^ ^ This posted on Fri Sep 29, 2006.
cboles wrote:I will be posting my code soon...
colby
Thanks Colby. Looking forward to an answer to my problem at last.
Sanctifier
Postby evo6TME » Thu Oct 19, 2006 6:30 am
any newsss???is it available for evo6 now???
evo6TME
Postby fotis_rs2 » Fri Oct 20, 2006 11:08 am
forget it.... they dont even answer to us....
anyway..
i've just bought a gems...
fotis_rs2
Postby evo6TME » Fri Oct 20, 2006 1:41 pm
gems..?hımm..could u give a little information about gems?where did u buy it?is it a standalone unit?
evo6TME
Postby HOK » Sun Oct 22, 2006 3:12 am
its not like this is a paid service... a little more patience besides you should be depending on this anyways..
HOK
Postby Michal_6 » Tue Nov 14, 2006 2:06 pm
evo6TME wrote:gems..?hımm..could u give a little information about gems?where did u buy it?is it a standalone unit?
I've gems but it's pice of s..t. eg if you would like to run junectors at 90% duty you will never have engought resoultion in the map for stable idle and 1 time per 10 you'll stall the engine stoping at red light.
so I going to buy working ecu from evo 7 and then i'll be happy :-)
Michal_6
Postby evo6TME » Wed Nov 15, 2006 11:24 pm
is evo7 ecu work on evo6?is it possible to use it?
evo6TME
Postby evo6TME » Wed Nov 15, 2006 11:25 pm
evo6TME
Postby Evodoc » Mon Nov 20, 2006 12:32 pm
Yes it can I used a ralliart ecu evo 7 ecu and was able to run 30psi of boost.
Evodoc
Postby HOK » Mon Nov 27, 2006 10:14 pm
Evodoc wrote:Yes it can I used a ralliart ecu evo 7 ecu and was able to run 30psi of boost.
Do you think you can reflash it too then?!?!? :P
HOK
Postby BobbyBigLug » Mon Jan 29, 2007 6:25 pm
So is the 6 supported yet? Can I do an 8 ECU swap? Any help will be appreciated.
BobbyBigLug
