Evo 7 JDM 93390000
Evo 7 JDM 93390000
Postby salex » Sun Jul 30, 2006 1:35 am
Another Evo 7, JDM 93390000.
This car is one of the European Evos imported straight from Japan.
I have found no definition file that covers it yet...
Evo7 JDM 93390000.hex
Evo 7 93390000
(256 KiB) Downloaded 819 times
salex
XML
Postby mtcavity » Sun Aug 27, 2006 9:11 pm
Here is what I could find. I feel better knowing 1 or 2 people look it over.
EVO 7 JDM 93390000 - HEX - XML def..rar
(90.21 KiB) Downloaded 412 times
mtcavity
Barometric Pressure Table fix.
Postby mtcavity » Wed Aug 30, 2006 9:29 pm
Barometric Pressure Compensation = 3551
NOT -3351- !
2001 Mitsubishi Lancer Evo7 JDM (MT) [93390000] ROM-XML 7-29-07.rar
(89.43 KiB) Downloaded 397 times
mtcavity
Postby salex » Thu Aug 31, 2006 7:56 am
Thanks for the help!
I will compare it to what I have already managed to get from the ROM file and let you know!
salex
Postby SkyNight » Sat Jul 28, 2007 3:33 am
Correct "Boost limit":
3814
SkyNight
Postby mtcavity » Sun Jul 29, 2007 5:28 pm
Thank you! XML has been updated.
mtcavity
Postby sub7 » Tue Jul 31, 2007 8:43 am
Thanks for the update! Didn't see much different even after replaced my current 93390000.xml (21k) with the update one 15k. Boost limit reading remain same as before.
sub7
Postby SkyNight » Sun Aug 12, 2007 1:07 pm
<table name="Open Loop Load # 1" category="Fuel" address="3824" type="2D" scaling="Load8">
<table name="RPM" address="5402" type="Y Axis" elements="15" scaling="RPM"/>
</table>
<table name="Open Loop Load # 2" category="Fuel" address="383a" type="2D" scaling="Load8">
</table>
SkyNight
