Can anyone help complete the attached Def MN132750 and ROM?
Postby allcdsrus » Wed Jun 14, 2006 4:58 pm
When opening attached ROM it comes up unkown rom image and prompts the following..
I chose Evo7base and then it requires the rom identifier. This is as per what comes up
Address (in hex) = f52
Address (in bytes) = 4
indentifier = 93660005
can anyone complete the XML Definition file listed further down the post?
Thanks in advance
AC
evo8.hex
Hex with imobilizer code set to FFFF
(256 KiB) Downloaded 724 times
allcdsrus
Postby allcdsrus » Thu Jun 15, 2006 1:21 pm
Can anyone help me with the XML Def, or let me know if it works with an existing XML template.
Thanks in advance
AC
allcdsrus
XML deff
Postby Ladis » Mon Jun 19, 2006 10:22 am
Here is XML I wrote for your ECU.
It is not complete. Maybe someone else can dig out some more tables.
Put this file into: rommetadata\mitsubishi\evo
93660005.xml
EcuFlash XML def for 93660005 JDM FQ300 ECU
(4.3 KiB) Downloaded 794 times
Ladis
Postby allcdsrus » Mon Jun 19, 2006 11:20 am
Many Thanks Ladis
Here is hopeing someone can help complete the few missing tables with the Rom at the top of this post.
Many thanks
AC
allcdsrus
ECU Part number
Postby allcdsrus » Sun Jun 25, 2006 2:06 pm
My ECU part numer on the case is
MN132750
allcdsrus
Postby allcdsrus » Thu Nov 16, 2006 2:52 am
I have this sorted now. Thanks for all your help everyone
allcdsrus
