European EVO 8 2004
European EVO 8 2004
Postby Ladis » Mon Jun 12, 2006 10:38 am
Hello,
I have just downloaded ROM from my stock EVO 8. This ROM is not recognized by EcuFlash. If I use other EVO8 xml as template I got wrong results, maps seems OK, but units in tables like RPM or Load are wrong. I am attaching my ROM. Can you help me please crate correct XML definition? Thank you.
evo8.bin
Stock european 2004 EVO 8
(256 KiB) Downloaded 912 times
Ladis
Postby S54fan » Mon Jun 12, 2006 12:11 pm
UNCONFIRMED:
Fuel:33BD,34D7
Ignition:39D5,3B5D
Postby burgers » Tue Jun 13, 2006 8:26 am
Hi
xml deffintion 94170008 , USDM evo 8 2004 reads this bin file OK, all the normal peramiters can be seen.
MB
burgers
Postby Ladis » Thu Jun 15, 2006 4:52 am
Thank you guys, I will try it.
Ladis
Postby mlr » Tue Jun 20, 2006 1:58 pm
Compared this ECU with mine (EDM EVO8 2004) -the same except 3FFCE -i suppose its immobiliser.
Exchanged injectors to 780cc and changed injector scailing - IT WORKS!-TNKX Colby!!! Great device!!!
But i hope to finds correct axis numbers for some boost control and injector latency tables.
Also there is a question where to find MAF(MAV) calibration table - i'd like to know what is the top mav reading this ecu can handle....
As i suppose-it reads mav impulses between CAS - an it is engine load...So then at high RPM is capable for higher MAF(V) readings , then on low, right?
mlr
