Hello from a V owner with a few ECU's
Postby ON-UJAH » Mon May 22, 2006 4:52 am
Hi,
Great project - I can't wait to get started and maybe be able to contribute someday.
Anyway, I currently run a V, and have at my disposal a VI ECU from Japan, with 180kmh limiter, a V ECU without the limiter (European I presume), and a RA VI ECU 'Fast Road' - I'm hoping to be able to play about with the Jap ECU, see what can be done, using the others for comparison.
I've ordered my cable from Tactrix - I had tried to connect using an OBD-II interface (OBD-DIAG® 2055 Interface) but had no joy. It seems the V is not OBD compliant.
So, until the Tactrix cables arrive, is there anything I should be reading up on or any other information I need to know?
THANKS
ON-UJAH
(ON or ON-U is good too)
ON-UJAH
Postby Evo4Mad » Thu Jun 01, 2006 10:13 pm
has your cable arrived yet? I'd like to see some evo5 roms on here.
Postby GTODesign » Fri Jun 02, 2006 12:21 am
E5/6 Kernel is not ready yet.
GTODesign
Postby Evo4Mad » Fri Jun 02, 2006 1:22 am
Thanks GTODesign, thats what I wanted to confirm :)
Postby Sanctifier » Thu Aug 03, 2006 2:00 pm
Another problem arises. AFAIK there's no additional re-flash plug in the E5 either...
GTODesign wrote:E5/6 does have the second init connector but the E4 doesn't.
E5/6 uses a different MCu to E7/8 which may explain why you are having problems with your OBDII loggers.
GTO I'm afraid that neither the E6 GSR or E6 RS2 (my model) have the second re-flash socket.
I am trying to initialize my Evo 6 RS2 ECU with the Tactrix OpenPort 1.3M cable.
I read this in another thread. Not sure if it also applies to my problem...
cboles wrote:...The new Mitsubishi cable needs and uses these drivers, (sic~ FT2DXX drivers/DLL) but since
there is no other software which works with that cable yet, there are no legacy support issues.
Unlike the Evo 7-9 models, the Evo 6 RS2 has no additional socket alongside the
OBDII port under the dashboard.
I'm looking for an alternative connector or wire that can be used on the
1999-2000 Evo 6 RS2s (with Immobilizer) for initialization to reflash the ECU.
I know that the Evo 6 software is still a work-in-progress... but this seems
to be more of a hardware issue that will have to be addressed anyway.
At the moment any attempt to initialize results in this error message...
"H8/500 processors are not yet supported!"
Any help or advice appreciated.
Sanctifier
Postby telecaster » Tue Nov 14, 2006 7:28 am
Any updates or success in flashing the V/VI ecu's?
telecaster
Postby Evo4Mad » Thu Nov 16, 2006 2:22 am
EvoScan will connect for MUTII datalogging on evo4 evo5 and evo6 +
http://www.limitless.co.nz/EvoScan
I too am hanging out for Evo5/6 reflash support! Please colby... it would be very much appreciated...
cobly HELP!!!
Postby spooky » Wed Feb 28, 2007 9:08 am
I share the same sediments....Evo5/6 reflash support pls...
colby HELP!!!!
Evo4Mad wrote:EvoScan will connect for MUTII datalogging on evo4 evo5 and evo6 +
spooky
Re: cobly HELP!!!
Postby BarryC. » Fri Mar 02, 2007 10:44 am
spooky wrote:I share the same sediments....Evo5/6 reflash support pls...
colby HELP!!!!
To be honest from what Ive read on another thread, Colby tried and I dont think he could get it to work, maybe he aint got the time or resourses to develop the kernel, I dont know but maybe he could tell us the situation on this instead of people just guessing all the time, me included, a statement stating if he is still working on this or not would be greatly appreciated from me anyway,
I dont mean to put the pressure on as I know this man has done great things to allow people to access and update the ECU software in their cars.
BarryC.
Postby Evo4Mad » Fri Mar 02, 2007 3:40 pm
it wasn't speculation, that was the case.. Colby is still working on it. I know he has been working on a problematic subaru kernal as of late. He will get to doing it, he knows how much everybody is keen for it.
Postby BarryC. » Sun Mar 04, 2007 12:36 pm
Evo4Mad wrote:it wasn't speculation, that was the case.. Colby is still working on it. I know he has been working on a problematic subaru kernal as of late. He will get to doing it, he knows how much everybody is keen for it.
Good stuff thanks for that.
BarryC.
