EVO X crancking problem
Postby raulhp » Fri Sep 07, 2012 7:45 am
Mitsubishi evo10_fede_mod_850cc_2injector.hex
(1 MiB) Downloaded 795 times
Hello
I have tuned a Mitsubishi EVO X with big turbo (GTX3071R) and injectors (deatchwerks 850cc). The car runs great, trims are under good values, but i have a problem
This ecu XML does have the Cranking Enrichment IPW adder Table, so every some starts the car has always the same DTC, "System too rich Bank 1". I raised and lowered the injector battery voltage latency compensation and fuel injector scaling tables to solve the problem, and the only think i got is problems with the start or black smoke on the tail.
I logged the trims when the car starts, and i see that the first 8-10 seconds the trims are zero, (the sensor is going hot) after that the trim goes to -10/-15 during 20 seconds and after that goes to -1 to +1 (when the starting enrichment map goes out).
Can any one get me a idea? can any one modify the xml to have the cranking enrichment ipw adder on my map?
I added the tuned map and the xml for this one
53050006.xml
(30.51 KiB) Downloaded 826 times
53050007.xml
(501 Bytes) Downloaded 808 times
raulhp
