Help with 2008 lancer CVT turbo conversion
Postby devojet » Thu Mar 29, 2012 6:32 pm
I have a 2008 lancer CVT NA which is currently being fitted with a turbo. I have ordered an openport 2, but have to wait for it to arrive. Can anyone help me with what XML file is required and what I would need to change to allow me to tune the fuel and timing for boost. The plan is to only run 5psi boost.
Daniel.
devojet
Re: Help with 2008 lancer CVT turbo conversion
Postby boymay22 » Fri Mar 30, 2012 12:16 am
Turbo for cvt is very bad. Standby a gearbox.
boymay22
Postby devojet » Sat Mar 31, 2012 3:59 pm
I have told the owner that but they want the turbo anyway. I'm just tuning it.
From the reading I have done it looks as though I need to use the evo x rom in the stock computer with an evo x MAP sensor. But that will still leave me with a check engine light that no one seems to know how to fix. Can anyone tell me if Im on the right track here?
Thanks Daniel.
devojet
Postby LiX » Wed Sep 26, 2012 2:43 am
Yes, you will need 3 bar Evo X map sensor, cause stock one is not reading boost. Also with Evo X ROM you will have CEL and MIVEC will be disabled.
If you don't want to have CEL you will have to install aftermarket piggy-back ECU - AEM FIC8
LiX
