2005 outlander
Thu Dec 29, 2011 12:29 pm
by aatsi
Hello. How to flash 2005 2.0 turbo EDM outlander? main problem is different "flash" connector?
Re: 2005 outlander
Tue Jan 10, 2012 2:16 pm
by altug
you need the correct definition files for 2005 outlander turbo. plus yu need to redo your reflash connector.
Re: 2005 outlander
Tue Jan 10, 2012 4:04 pm
by radsdau
altug wrote:plus yu need to redo your reflash connector.
Any details on this?
Re: 2005 outlander
Tue Jan 10, 2012 11:53 pm
by altug
Flash connector is not the only problem with outlander turbo 2.0. Your car has MH8202F processor. This type of processor does not have definition files to read and write to ecu. However, what you should do is to buy MMCFLASH software from Evoscan. As the technical guy called hamish states tha MMCFLASH can successfully read and write MH8202F processor type. As far as female 13 pin reflash connector on your car, you should cut it out the connector. Just cut the audio jack on your reflash connectors and attached on your green wire. This is the only way for now... Good luck..
Re: 2005 outlander
Tue Jan 10, 2012 11:57 pm
by altug
ANY ONE HAS DEFINITION FILES FOR OUTLANDER TURBO WITH MH8202F PROCESSOR?
ANY HELP IS GREATELY APPRECIATED
