2005 outlander
2005 outlander
Postby aatsi » Thu Dec 29, 2011 12:29 pm
Hello. How to flash 2005 2.0 turbo EDM outlander? main problem is different "flash" connector?
aatsi
Re: 2005 outlander
Postby altug » Tue Jan 10, 2012 2:16 pm
you need the correct definition files for 2005 outlander turbo. plus yu need to redo your reflash connector.
altug
Re: 2005 outlander
Postby radsdau » Tue Jan 10, 2012 4:04 pm
altug wrote:plus yu need to redo your reflash connector.
Any details on this?
Re: 2005 outlander
Postby altug » Tue Jan 10, 2012 11:53 pm
Flash connector is not the only problem with outlander turbo 2.0. Your car has MH8202F processor. This type of processor does not have definition files to read and write to ecu. However, what you should do is to buy MMCFLASH software from Evoscan. As the technical guy called hamish states tha MMCFLASH can successfully read and write MH8202F processor type. As far as female 13 pin reflash connector on your car, you should cut it out the connector. Just cut the audio jack on your reflash connectors and attached on your green wire. This is the only way for now... Good luck..
altug
Re: 2005 outlander
Postby altug » Tue Jan 10, 2012 11:57 pm
ANY ONE HAS DEFINITION FILES FOR OUTLANDER TURBO WITH MH8202F PROCESSOR?
ANY HELP IS GREATELY APPRECIATED
altug
