2002 Lancer ES A/T
2002 Lancer ES A/T
Postby SPD_FRK » Thu Nov 17, 2011 6:21 pm
I am in need of a definition file for a 2002 Lancer ES, A/T Model. I have a few of the currently made Lancer XMLs but none that seem to be working with this ROM file.
2002 Lancer ES.bin
(256 KiB) Downloaded 763 times
SPD_FRK
Re: 2002 Lancer ES A/T
Postby acamus » Fri Nov 18, 2011 2:08 am
First of all you have to repull the ROM, the size for AT ECU is 512kB, so memory model shall be 7055.
Secondly search for newer version 88560021 and use this for tuning.
e.g. http://code.google.com/p/ecurom/source/ ... ncer/?r=64
acamus
Postby SPD_FRK » Fri Nov 18, 2011 7:17 am
Yea I remember we had a similar issue with the 8th Gen Galant ROM files as well. We did find that some of the ROMs that were 256kb size, and in the A/T vehicles was actually the full ROM file for those ECUs. I am wondering if this Lancer ROM is the same thing. I have pulled it 4-5 different times using two seperate 20 cables and same results.
How can I download that XML in the link you posted? Or do I simply copy and paste into a new XML and name it accordingly?
SPD_FRK
