Definition XML for MD362115
Postby DeeGraf » Sun Oct 02, 2011 3:09 am
Hi all!
Please help me to create a valid definition XML for my ecu.
Make: Mitsubishi
Model: Space Star
Market: EDM
Year: 1998
Engine: 4g93 GDI
ECU ID: E53F
HW: MD362115
SW: EM1325
CPU: MH7201F
Interface: OpenPort 2 With MMC Flash Usb Module for MH7201F.
Help greatly appreciated!
Thanks in advance.
Regards!
Space Star 4g93 GDI.hex
(128 KiB) Downloaded 890 times
DeeGraf
Re: MD362115
Postby acamus » Sat Oct 08, 2011 9:42 pm
Seems to be incomplete.
acamus
Re: Definition XML for MD362115
Postby DeeGraf » Sun Dec 18, 2011 4:19 am
No one? Rom is Complete!
3 month and one incorrect answer?
DeeGraf
Postby DeeGraf » Mon Dec 19, 2011 9:22 am
Yes, Filesize OK, i've read out my Ecu again, No errors reported, exately the same result as i posted came out.
Need xml with tables etc. in it.
DeeGraf
Postby DeeGraf » Mon Dec 19, 2011 10:02 pm
I know that it is difficult to find a XML for this ECU! This is why i post my ecu to this Forum. But not to find out that it is difficult to create or find a xml.
Please someone help. Any ideas, how or where i can get help to create / find xml for this rom?
DeeGraf
Postby DeeGraf » Tue Dec 20, 2011 8:36 am
Marcello wrote:the software code is at $1FEFA EM1325
Thanks! Aleready got it. Found other Maps with Analyzer.exe. High n Low Octane Fuel maps i think it's right.
Other offset's i don't know what is what i saved to konck filter's. Does anybody know how to find load and Rpm for x y in maps? Not found it yet.
Have a look
Rom n XML.zip
(72.87 KiB) Downloaded 669 times
DeeGraf
Postby GMS » Tue Dec 20, 2011 11:57 am
For Fuel Map: RPM 4A42, Load 4A67. Ignition Map 16x12: 17DA, 18A1, 1968, 1B19, 1BE0, 1CA7.
GMS
Postby DeeGraf » Tue Dec 20, 2011 12:32 pm
GMS wrote:For Fuel Map: RPM 4A42, Load 4A67. Ignition Map 16x12: 17DA, 18A1, 1968, 1B19, 1BE0, 1CA7.
Thank you Soo MUCH!!
But... Question, when i put in these ofsets (which all be correct, thanks again!) and i take load8 and rpm8 i get every second position a 0. Values plausible ( load p.e. 80.0 0.0 120.0 0.0 0.0 0.6,, confusing values)
DeeGraf
Postby GMS » Wed Dec 21, 2011 12:55 am
RPM 16 and Load 16,
GMS
Postby DeeGraf » Wed Dec 21, 2011 3:37 am
Stock Rom incl def xml.rar
(66.4 KiB) Downloaded 587 times
Thank you!
Rom and Xml updated.
Please help me to find more maps!
DeeGraf
Postby DeeGraf » Fri Mar 02, 2012 1:56 am
In my garage we have lot 4g93 GDI with an Idle Problem. My boss asked me if i can set the idle Rpm a little bit higher. Can someone help me to find the desired idle Rpm table?
When i log the idle RPM from my own Space Star (4g93GDI) it's 625.
Here the Stock Rom from the GDI (EM1325) with the def xml.
Stock Rom with Base n Def XML.rar
(67.54 KiB) Downloaded 578 times
DeeGraf
Postby DeeGraf » Sat Mar 03, 2012 6:39 pm
Yes Rev limiter is 7000
Fuel Cut too
Yes wrote several times to ecu. changes took effects. ok, then i think no checksums are active..
You can give me the offets of the idle rpm's. i will change it and write it to my ecu and test it.
Searching Injectorscaling, i logged fuel trim's.. terrible...
DeeGraf
Postby DeeGraf » Tue Mar 06, 2012 10:55 am
Now i've tested the Idle Target Rpm. Got it!
Offset: 180
5 x 5 Table
Rpm8 Scaling
Added to XML
Here Newest XML and Stock ROM
Thanks!
Please help me to find the injector Scaling value.
XMLs and Stock Rom.rar
(67.98 KiB) Downloaded 564 times
DeeGraf
Postby DeeGraf » Sat Apr 07, 2012 1:04 am
Found Injector Scaling, Fuel Pressure Maps, Barometric Pressure Compensation, Idle Maps, Alternator Charge Map, Egr Timing Advance and Periphery Bits.
New Xml, n Rom posted.
Have a look
Searching injector Latency, Throttle percentage, and Maf Smoothing tables.
Many maps, i dont know what they are, saved in Misc, please help me to identify.
EM1325.xml
(15.55 KiB) Downloaded 914 times
Stock.hex
(128 KiB) Downloaded 908 times
evo5base.xml
(7.21 KiB) Downloaded 890 times
DeeGraf
