Help needed, definition for EDM 2011 RalliArt Lancer
Postby needle » Wed Aug 17, 2011 2:55 am
Hi,
Car is EDM 2011 Ralliart Lancer. ROM attached. Appreciate your help. ROM ID: 56950006
2011_RA_EDM_Stock.hex
2011 RalliArt EDM stock ECU
(1 MiB) Downloaded 919 times
needle
Re: Help needed, definition for EDM 2011 RalliArt Lancer
Postby needle » Fri Aug 19, 2011 12:22 pm
Here's my work so far, if someone is taking a shot at this. Not sure if everything is correct, but I've put some comments in the XML. I'm at Cylinder Fuel Trim #4, and I haven't found two of the Mode 23 logging locations. I will continue downwards from here once I have time.
56950006_work_in_progress.xml
Work in progress
(41.6 KiB) Downloaded 939 times
needle
Postby Thane » Sat Aug 20, 2011 2:07 am
here is a updated version, now only missing Mode 23
56950006.xml
(28.7 KiB) Downloaded 927 times
Thane
Postby And » Wed Aug 24, 2011 11:23 pm
<table name="Mode 23 - IFMode 0x05 -> 0x23 #1" category="Misc" address="7f6ab" type="1D" scaling="Hex8"/>
<table name="Mode 23 - IFMode 0x05 -> 0x23 #2" category="Misc" address="8acff" type="1D" scaling="Hex8"/>
<table name="Mode 23 - DoMode 0x4B -> 0x5B" category="Misc" address="8ad06" type="1D" level="4" scaling="Hex16"/>
And
