99 Galant A/T Cali Spec ROM Needed
Postby SPD_FRK » Fri Apr 15, 2011 6:34 pm
I have two other definitions for the 99 ROM files, however this ROM (from what we know of the vehicle) was from a 1999 Cali Spec Galant, thus why it is a 128kb size. The definitions I have currently do not work with this ROM file. I need a definition for this ROM to adjust the normal items (fuel, ignition, etc..) also need to have injector scaling and latency tables as this is for a 3.5L swapped Galant.
99V6 Cali Spec.hex
(128 KiB) Downloaded 760 times
SPD_FRK
Re: 99 Galant A/T Cali Spec ROM Needed
Postby beam514 » Sun Apr 17, 2011 12:14 pm
If the definition for my 99 V6 Cali Spec ends up working out, I wonder if we can just change the definition ID within the definition so that EcuFlash recognizes it and utilizes it.
For example, my definition ID is 20410017, and it is clearly defined within the def. file.
The definition you need is 20410015, and you can easily change this in the file.
My theory is that the ROM changed ID's when the dealer did any ECU reflashing that had to do with recalls for this car. The Galant you are talking about may not be as up-to-date on dealer reflashes. Anyway, from my limited knowledge, I think the definition file just sets up the ROM info into a viewable, user friendly format for EcuFlash, so the tables and stuff should still work out if we just change the internal definition ID. (?)
beam514
Postby SPD_FRK » Sun Apr 17, 2011 6:26 pm
I worded the topic title wrong it looks like. I need the definition not the ROM lol...
Anyways, the ROM ID I have to work with is 20410015 and I have the definition, however it appears that some of the tables are not defined correctly so the RPM and Load values in many of the tables is not registering correctly. If somebody can clean this definition up or double check to make sure it is correct it would be greatly appreciated.
20410015.xml
(22.05 KiB) Downloaded 586 times
SPD_FRK
