2008+ NA Lancer Definition Files
As some of you might know ClubCJ.net in Australia, has taken the extraordinary effort of releasing the Definition files for the AuDM 2008+ NA Lancers.
With the Turbo variants of this Lancer release already defined so well by both Tephra and Golden, I would like to get the same done for the NA variants.
Under the guidance of Thane from this forum and Golden of Goldenevo fame, I have been able to define the following ECU IDs:
52190007 = MY08 4B11 MT
52200010 = MY08 4B11 CVT
52200013 = MY09 4B11 CVT
53770004 = MY09 4B12 MT
53780004 = MY09 4B12 CVT
54320001 = MY09 4B11 MT
54760002 = MY10 4B11 MT
54770004 = MY10 4B11 CVT
These are now completely listed with the following Tables and Maps:
This Ver 3.0 release has the following tables and maps (Additions are shown in Bold):
Misc
ECU ID
Mode 23 -
IF Modes and
DoMode <- Still faulty in : 54760002 and 54770004.
Timing
High Octane Timing Map
Low Octane Timing Map
Unknown Timing Map 1
Unknown Timing Map 2
MIVEC Intake Normal Coolant Temp
MIVEC Intake Low Coolant Temp
MIVEC Intake Map Interpolation
MIVEC Exhaust Normal Coolant Temp
MIVEC Exhaust Low Coolant Temp
MIVEC Exhaust Map Interpolation
Ignition Warmup Retard
EGR Timing Advance
Upper Bound Ignition Timing
Lower Bound Ignition Timing
Timing Reduction vs Load/RPM
IAT Ignition Advance Compensation
Limp Home Table #1
Limp Home Table #2 <-All added in Ver2.0 (unreleased)
Fuel
High Octane Fuel Map
Low Octane Fuel Map
High Octane Fuel Map #2
Low Octane Fuel Map #2
Fuel Injector Scaling
Injector Battery Voltage Latency Compensation
Injector Base Latency
MAF Scaling Part 1
MAF Scaling Part 2
MAF Scaling Part 3
Evap Map #1
Evap Map #2
Open Loop Load Low Octane #1
Open Loop Load High Octane #1
Open Loop Load Low Octane #2
Open Loop Load High Octane #2
Cylinder Fuel Trim #1
Cylinder Fuel Trim #2
Cylinder Fuel Trim #3
Cylinder Fuel Trim #4
Closed Loop - LT Trim Control <- Added in Ver3.0
Intake
Throttle Map #1
Throttle Map #2
Throttle Map #3
Throttle Contditional Switch
Limits
Rev Limiter
Stationary Rev Limiter
Speed Limiter
Airflow Check #1
Airflow Check #2
Airflow Check #3
Torque Limiter #1
Torque Limiter #2
Torque Limiter #3
Idle
Idle RPM #1 vs Coolant Temp
Idle RPM #2 vs Coolant Temp
Idle RPM #3 vs Coolant Temp
Idle RPM #4 vs Coolant Temp
Idle RPM #5 vs Coolant Temp
Idle RPM #6 vs Coolant Temp
Target Idle #1
Target Idle #2
Target Idle #3
Target Idle #4
Target Idle #5 <-Added in Ver3.0
OBD II Inspection
Non-Continuous Monitor Availability Patch - Part 1
Non-Continuous Monitor Availability Patch - Part 2
Non-Continuous Monitor Completion Patch
Monitor Available(1)/Not Available(0) - Read Only, Do NOT Change
Monitor Passed(1)/Failed(0) - Read Only, Do NOT Change <-Added in Ver3.0
OBD II Codes
OBD II Codes
ECU Options
ECU Options Set #1
ECU Options Set #2
ECU Options Set #3
ECU Options Set #4
ECU Options Set #5
ECU Options Set #6
ECU Options Set #7
MUT
MUT Tables
Eventually, all of these in Ver1.0 will be submitted to Golden himself for free release on the Goldenevo site.
Those who wish to obtain the Ver3.0 and further releases may choose to join ClubCJ.net as a premium member.
What does this mean for you?
In the meantime, should anyone else around the world wish for me to provide a definition file for you, please put up a copy of your ROM file in this thread and I'll get it defined so we can build up a database for the NA Lancers too.
Please give me some details on the ROM like: MY??, MT or CVT, 4B11 or 4B12, which domestic market it's from.
After doing these many definition files, it doesn't take me more than half an hour to do a single def file. Learning curve was steep to begin with though... .
*edit*
I have so far begun work on the definition files for the following ROMs I've found on this forum but would appreciate more information if you were the ones that put up these files (* => completed to Ver3.0):
50840023 -No info
51510022-??DM-MY084B11 - No info
51510023-USDM-MY084B11 - No info
51520020-??DM-MY084B11 - No info
51930007-EDM-MY084B11 - No info
52170007*-SADM-MY084B11 - No idea bout transmission type
52180010-??DM-MY??4B11 - No info
52310001-??DM-MY??4B?? - No info
55170006*-??DM-MY??4B?? - No idea about Market, year of manufacture nor engine type though looks like a 4B11
Definition Files Supplied
1.
2. 57370001-MyDM-MY114B10MT-Inspira.xml - edmundturner
3. 54980003-MyDM-MY104B10 MT-Lancer.xml - edmundturner
4. 5500010-EDM-MY094B10MT-Lancer.xml - LiX *DONATED*
Authored by: ofey of ClubCJ.net
Supported by: Thane of Openecu.org and Golden of Evolutionm.net
Background: This file is part of a set of definition files for AuDM CJ Mitsubishi Lancers 2008+
released by ClubCJ.net for their Premium Members only use. Of which this is the third iteration. Further details are available from http://clubcj.net/.
To the best of our knowledge, these are the first ever disclosure of defintion files for NA Lancers in
the public domain. Please respect the licensing of these files.
Licensing: These are released under the creative commons licence (CC BY-NC-SA 3.0) -
http://creativecommons.org/licenses/by-nc-sa/3.0
Disclaimer: This file is supplied as is. Use at your own risk.
Revision: 5XXXXXXX Ver 3.0 (4 Feb 2011)
Misc
ECU ID
Mode 23 -
IF Modes and
Timing
EGR Timing Advance
Limp Home Table #1
Fuel
Low Octane Fuel Map
MAF Scaling Part 1
MAF Scaling Part 2
MAF Scaling Part 3
Evap Map #1
Evap Map #2
Intake
Throttle Map #1
Throttle Map #2
Throttle Map #3
Limits
Rev Limiter
Speed Limiter
Airflow Check #1
Airflow Check #2
Airflow Check #3
Torque Limiter #1
Torque Limiter #2
Torque Limiter #3
Idle
Target Idle #1
Target Idle #2
Target Idle #3
Target Idle #4
OBD II Inspection
OBD II Codes
OBD II Codes
ECU Options
ECU Options Set #1
ECU Options Set #2
ECU Options Set #3
ECU Options Set #4
ECU Options Set #5
ECU Options Set #6
ECU Options Set #7
MUT
MUT Tables
*edit*
50840023 -No info
1.
