Eclipse Gst 1998 - MD355783
Postby vinibarr » Mon May 31, 2010 11:08 am
Hello friends, I downloaded the map from my ECU, changed the fuel map and I upload using EcuFlash.
But the expected result did not happen. I can not tune the fuel mixture poorer.
Has some important detail that I need to know or do to adjust the fuel mixture?
I use a Wideband A & M.
vinibarr
Re: Eclipse Gst 1998 - MD355783
Postby vinibarr » Mon May 31, 2010 11:15 am
ECU Mode: MD355783 / E2T68280 H1 7929 - JE331B153C
Ecu Id Ascii: EM2263
Chassi Number: 4A3AK54FBWE800030 Model D32AMNGFLFB
Eclipse Gst 1998
vinibarr
Postby vinibarr » Mon May 31, 2010 11:16 am
I remembered one important thing
When I download the map from my car I get four maps:
High Octane 1 and 2
Low Octane 1 and 2
What is the difference between 1 and 2 ?
The first phase is aspirated, the second stage turbo ? or the first loop is close and the second is open loop?
vinibarr
Postby ed_GST » Sat Aug 07, 2010 9:49 pm
This Def will work with your ECU
If your ROM has a different ID change it in the definition
Thats a good start
20550010.xml
(32.98 KiB) Downloaded 903 times
ed_GST
