Mitsubishi ECU IDs 1860A700 & 1860A947
Postby chaeoz » Thu Nov 19, 2009 2:36 am
Hi,
Does anyone have the XML Definitions for the above Mitsubishi ECU IDs?
chaeoz
Re: Mitsubishi ECU IDs 1860A700 & 1860A947
Postby todd-w » Thu Nov 19, 2009 1:37 pm
what car ,year , model ???
todd-w
Postby chaeoz » Thu Nov 19, 2009 6:36 pm
Sorry, posted that in a rush.
Mitsubishi i, one of them is a 06/07 JDM Model, the other is a 08/09 EDM Model.
Anyway to pull out the unknown ROMs? We know they are running Densos. Unfortunately, due to the design of the car, the ECUs are a bit hard to reach.
chaeoz
Postby todd-w » Fri Nov 20, 2009 10:40 am
:lol: mitsubishi what model though ? or if you have the roms attach them .
todd-w
Postby chaeoz » Sun Nov 22, 2009 6:37 pm
Hi Todd,
They are "Mitsubishi i". As in the model is a "i".
How do I pull up the ROMs? I would love to pull them up for you guys to have a look.
chaeoz
Postby todd-w » Mon Nov 23, 2009 3:05 pm
try ecuflash ,never heard of an "i" :? show us a pic
todd-w
Postby chaeoz » Mon Nov 23, 2009 6:32 pm
Here's a pic.
Tried ecuflash, but it tries an init to read and then fails.
I know the JDM model seems to have a reflash block, but the EDM doesn't. Apparently, they are both CANBUS systems.
We tried shorting different leads from the reflash block but no luck either.
I was trying to see if ecuflash has some option to try and pull unknown ROMs but I couldn't find it or I'm missing something...
chaeoz
Postby todd-w » Tue Nov 24, 2009 11:44 am
how many init codes does it try ?? if you can post up the ecuflash log .
todd-w
Postby chaeoz » Tue Nov 24, 2009 8:15 pm
Let me try and get that to you.
Thanks todd.
chaeoz
Postby christian_piasini » Tue Dec 01, 2009 1:24 am
Can someone has this car write the details, and get few pictures of the ecu out ?
Best regards
Postby todd-w » Tue Dec 01, 2009 11:37 am
christian_piasini wrote:Can someone has this car write the details, and get few pictures of the ecu out ?
Best regards
Is this one that Serial suite Paisiniengineering CANNOT offer ??? 8) 8)
todd-w
Postby christian_piasini » Tue Dec 08, 2009 1:18 pm
Maybe we support it already, but I can't tell if i don't see the ecu ! ;-)
Best regards
CHristian Piasini
adding jetski.txt
(3.06 KiB) Downloaded 930 times
3.2.0-revision44.txt
(37.73 KiB) Downloaded 909 times
Postby todd-w » Wed Dec 09, 2009 1:28 pm
:lol: all one way traffic here
todd-w
Postby chaeoz » Wed Jan 20, 2010 10:22 pm
Okay, after a long while, I managed to get my hands on the ROM pull logs from a friend of mine who tried it.
Here it goes.
[17:01:56.609] EcuFlash Version 1.42.2595
[17:01:56.609] OS Version Windows XP
[17:01:56.609] Qt Version 4.5.0
[17:01:56.625] 56 memory models read.
[17:01:56.625] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[17:01:57.093] 425 ROM metadata models scanned.
[17:01:57.109] checksum module "subarudbw" loaded.
[17:01:57.109] checksum module "mitsucan" loaded.
[17:01:57.109] flashing tool "wrx02" loaded.
[17:01:57.109] flashing tool "wrx04" loaded.
[17:01:57.109] flashing tool "sti04" loaded.
[17:01:57.109] flashing tool "sti05" loaded.
[17:01:57.109] flashing tool "mitsukernel" loaded.
[17:01:57.109] flashing tool "mitsukernelocp" loaded.
[17:01:57.109] flashing tool "mitsubootloader" loaded.
[17:01:57.109] flashing tool "shbootmode" loaded.
[17:01:57.109] flashing tool "shaudmode" loaded.
[17:01:57.109] flashing tool "subarucan" loaded.
[17:01:57.109] flashing tool "mitsucan" loaded.
[17:02:03.093] J2534 API Version: 04.04
[17:02:03.093] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[17:02:03.093] Device Firmware Version: 1.10.2721
[17:02:04.421] -- loading kernel --
[17:02:04.421] -- connecting to kernel --
[17:02:04.421] kernel get version
[17:02:04.765] ECU HW part number : 1860A947
[17:02:04.781] ECU SW part number : 1860A94700
[17:02:04.796] -- unlocking ECU --
[17:02:04.796] starting session...
[17:02:04.796] requesting seed...
[17:02:04.812] interface close
[17:02:04.828] interface close
Any ideas on how to proceed from here?
chaeoz
Postby chaeoz » Thu Jun 17, 2010 2:46 am
No one?
chaeoz
