Need 86490000.xml file
Postby waskarn » Sun Sep 06, 2009 8:38 pm
Please help me for open 86490000.xml file for 4g-18 CVT THANKS
waskarn
Re: Need 86490000.xml file
Postby acamus » Mon Sep 07, 2009 9:11 pm
If you post ROM we migth help you.
acamus
Postby waskarn » Fri Sep 11, 2009 7:37 am
acamus wrote:If you post ROM we migth help you.
INTERNAL ID:86490000
ENGINE 4G18 1600CC
Transmission CVT
THANK YOU
waskarn
Postby racedude » Thu Dec 31, 2009 2:08 am
Heres the ROM, hope someone can help. Thanks
86490000lancer4G18p2005.hex
(512 KiB) Downloaded 795 times
racedude
Postby racedude » Thu Dec 31, 2009 5:49 am
HI, I successfully opened this ROM with the 85270000.xml. However when I downloaded the original 86490000 Rom with OP2, I had to use EVO9 memory map. The 85270000.xml can read the rom but changed the memory mapping to Evo 7 SH7055. How can I confirm if this memory map can work on the 86490000 ECU? Is it possible to change the memory mapping to the Evo9 memory?
Thanks.
RD
racedude
Postby racedude » Thu Dec 31, 2009 6:12 am
Oops My error, they are both using SH7055 memory schemes. Thanks.
racedude
