airtrek turbo jdm cant read rom
Postby leong1 » Tue Jul 28, 2009 10:02 pm
any body can help me
i have problem cant read rom .
i try many time to read the rom .
please help me ..
leong1
Re: airtrek turbo jdm cant read rom
Postby Danny Boy » Fri Aug 28, 2009 2:57 am
Hi,
Post your hex file and I will try to solve it for you.
The car is 2005 JDM?
Danny Boy
Postby todd-w » Fri Aug 28, 2009 1:27 pm
run the ecu unlocker in the background ,start the car and then try read
todd-w
Postby scientist » Sun Sep 20, 2009 6:07 pm
Did you connect the flash connector to the right port? I have tried 3 Airtreks so far and haven't had any issues, I had to DE-Pin the flash connector and wire it to the airtreks, since it uses a different connector from other mitsubishi's
scientist
Postby leong1 » Fri Nov 13, 2009 9:49 pm
HI, scientist
I DIDNT CONNECT THE FLASH SOCKET ... I DON'T KNOW HOW TO BY PASS THE FLASH CONNECTOR .
NOW I'M USING TACTRIX 2.0 . I HAVE CHECK FORUM POST THIS CONNECTOR BEFORE .. BUT THEY DIDNT SHOW HOW TO CONNECTOR TO CONNECT IT .
SO I HOPE YOU CAN HELP ME ... THANKS ANY WHERE .. I'M WAITING YOUR ANSWER ..
leong1
Postby leong1 » Fri Nov 13, 2009 9:52 pm
AIRTREK 2001Y TURBO JDM
leong1
Postby scientist » Sun Jan 10, 2010 7:28 pm
if you look under there, you will see another large connector next to the OBD/MUT connector...it will only have one pin in it. I used another wire to put into that pin and connected it to the flash connector on the ECU flash
scientist
Postby leong1 » Mon Jan 11, 2010 9:15 am
thanks ..... i will try it ..
leong1
