Galant 2000 reflashing
Postby AlGontsov » Wed May 27, 2009 8:28 pm
Hello!
Does anyone tried Galant 2000 2.5AT reflashing? Reading is fine, but on the flashing require smth more, erasing failed.
Tactrix OP2 + ecuFlash 1.41 has no luck (mitsukernel / ocp). Additional Mitsubishi connector has 2 wres, i'm test writing with using one and both of that wires, result the same.
Are there any ways?...
Sample ROM attached.
Thanks.
galant_2000_AT_2.5.hex
(128 KiB) Downloaded 773 times
AlGontsov
Re: Galant 2000 reflashing
Postby acamus » Wed May 27, 2009 9:29 pm
As far as I know, You need to have solid 16V at reflashing ECU PIN for H8 based ECU's
acamus
