XML for 4g18 Lancer 06? gulf/asian spec
Postby HsamehH » Tue May 12, 2009 4:50 pm
Hello i hope someone can help me with XML definition for 06 M/T lancer 1.6L 4g18 sohc,i tried all the definitions here but none of them worked for me :(.
Here is the stock rom.
4g18.hex
(256 KiB) Downloaded 852 times
HsamehH
Re: XML for 4g18 Lancer 06? gulf/asian spec
Postby acamus » Tue May 12, 2009 9:07 pm
ROMID = 91210002
ECU Family = JM9121
SCC = E235
acamus
Postby acamus » Tue May 12, 2009 9:27 pm
Here it comes
91210002.xml
(4.35 KiB) Downloaded 835 times
acamus
Postby HsamehH » Wed May 13, 2009 5:00 am
Thanks much,you are the man :D .
HsamehH
Postby HsamehH » Wed May 13, 2009 8:01 am
hi acamus is there update for this xml so i can read and rescale maff and injectors size,when installing turbo kit.:)
HsamehH
Postby acamus » Wed May 13, 2009 9:30 am
If you can find MAF installed on your machine, I will find it in ROM :D
But as far as I know 4G1x series are MAP controlled engines.
You have to modify Volumetric Efficiency table for the same.
I will try to find injector scaling.
acamus
Postby HsamehH » Wed May 13, 2009 11:51 am
thanks for helping :)
it's a shame on me haha,i didnt look well under the hood,
can you explain more about modifying the Volumetric efficiency,thanks.
HsamehH
Postby acamus » Wed May 13, 2009 9:43 pm
I am not a tuner, but DSM guys have some explanation http://www.dsmtuners.com/forums/articles-tuning-ecu/298781-explaining-volumetric-efficiency.html and some how to is at http://www.megamanual.com/ms2/tune.htm#ve
Here comes xml with Injector scaling
91210002.xml
(4.46 KiB) Downloaded 819 times
acamus
Postby HsamehH » Thu May 14, 2009 4:58 am
wow ! thanks a lot man it's working great but i don't see the injectors latency,i guess that's needed with larger injectors or not ?,thanks again :wink:
HsamehH
Postby acamus » Thu May 14, 2009 6:43 am
Latency Compensation included
91210002.xml
(4.6 KiB) Downloaded 877 times
acamus
Postby HsamehH » Thu May 14, 2009 3:43 pm
working like charm,thanks bro :)
HsamehH
