Definition File needed for Australian 4G94 Lancer
Postby Mitsiman » Tue May 05, 2009 2:37 am
Definition file from Mitsubishi Lancer with the 4G94 Lancer
Lancer 4G94 ADM CH Stock.hex
(256 KiB) Downloaded 928 times
Mitsiman
Re: Definition File needed for Australian 4G94 Lancer
Postby acamus » Tue May 05, 2009 9:19 am
ROMID = 99730001
ECU Family = EM9973
SCC = E57C
Does it have MIVEC head?
acamus
Postby acamus » Tue May 05, 2009 10:52 am
Here it comes
99730001.xml
(4.06 KiB) Downloaded 928 times
acamus
Postby Mitsiman » Tue May 05, 2009 5:00 pm
Thanks no this is for the baseline 4G94 SOHC 16v motor. Same as the ES Lancer in the USA 2003 - 2007 model.
I will give it a go thanks again
Mitsiman
Postby Mitsiman » Wed May 06, 2009 7:03 pm
I have another 4G94 lancer ROm I flashed, which needs a new definition file.
Lancer CS 2005 4G94.hex
(256 KiB) Downloaded 930 times
Mitsiman
Postby acamus » Wed May 06, 2009 11:49 pm
ROMID = 98490000
ECU Family = JM9849
SCC = E57C
acamus
Postby Mitsiman » Thu May 07, 2009 12:10 am
Acamas I am going to have to put you on my payroll at this rate :)
Let me know how you go with teh definition file.
Also secondly, for those that may know, many of these Mitsubishi vehcles are not running a knock sensor from factory. If we were to wire it in and somehow find the pin on the ECU, would the software automatically be able to utilise it or would we have to write a specific file to enable it?
Mitsiman
Postby acamus » Thu May 07, 2009 12:12 am
Here it comes
98490000.xml
(4.07 KiB) Downloaded 976 times
acamus
Postby acamus » Thu May 07, 2009 12:14 am
There is more to knock than wire it in, unfortunately.
Where do I withdraw paycheck money? :)
acamus
Postby Mitsiman » Sun Jun 07, 2009 5:17 pm
I have another model 4G94 needing a definition file. Thanks again to those who are helping.
CS Lancer 2004 MT Stock Rom.hex
(256 KiB) Downloaded 920 times
Mitsiman
Postby acamus » Mon Jun 08, 2009 11:11 am
You can use 2005 model definition just change the xml header and save as 94950001.xml
ROMID = 94950001
SCC = E57C
ECU Family = JM9495
<romid>
      <xmlid>94950001</xmlid>
      <internalidaddress>f52</internalidaddress>
      <internalidhex>94950001</internalidhex>
      <make>Mitsubishi</make>
      <market>ADM</market>
      <model>Lancer</model>
      <submodel>4G94</submodel>
      <year>2004</year>
      <flashmethod>mitsukernel</flashmethod>
      <memmodel>SH7052</memmodel>
   </romid>
acamus
Postby Mitsiman » Mon Jun 08, 2009 10:46 pm
Thanks worked a charm.
Mitsiman
Postby Mitsiman » Thu Jul 02, 2009 11:51 pm
I have another variation of the 4G94 this time an Auto model.
Would someone have a look at this one for me please thanks
CG Lancer 4G94 Auto.hex
(512 KiB) Downloaded 858 times
Mitsiman
Postby acamus » Fri Jul 03, 2009 12:03 pm
Same as above, save as 84970001.xml
   <romid>
      <xmlid>84970001</xmlid>
      <internalidhex>84970001</internalidhex>
      <transmission>Auto</transmission>
      <year>2006</year>
      <memmodel>SH7055</memmodel>
   </romid>
acamus
Postby HsamehH » Sun Apr 11, 2010 7:20 am
hi acamus, I have this one too from manual 4g94 lancer but ecuflash can't open it with this xml's :(
4g94stock.hex
(256 KiB) Downloaded 866 times
HsamehH
