Help Please : I can't read or write on my TME ECU OP 2.0
Postby madmax1379 » Thu Apr 30, 2009 2:44 pm
I use Open port 2.0 with ecuflash 1.41
And i can't read or write on my OEM ECU ?
I use win XP pro SP3, .net 3.5 ?
I try with evo VIII UDM with harness and i had the same things ...
Could you help me please ?
madmax1379
Re: Help Please : I can't read or write on my TME ECU OP 2.0
Postby madmax1379 » Fri May 01, 2009 3:35 am
I Swap pins 8 and 22
Connect 31 from the ECU to 34 on the vehicle harness
Connect 31 from the ECU to 20 on the vehicle harness
Connect 32 from the ECU to 21 on the vehicle harness
Disconnect pin 87
All is good, but i can't read or write on my ECU with open port 2.0.
madmax1379
