06 Eclipse 4cyl AT
06 Eclipse 4cyl AT
Postby itp » Thu Feb 05, 2009 5:27 am
I tried pulling the ROM from an 06 (prod. date 3/06)USDM 4cyl AT Eclipse. I am using 2.0 cable and 1.41Ecuflash. It did not seem to initialize. It tried 3 diff(0001,0003,ffff) init. codes and all failed. In the car type menu the 1.41 software has the 06 eclipse AT listed already. I tried 06+ CAN Mitsu as well. No dice. Other thing is that I did not see the secondary (initialization?) connector. Maybe this is the problem. I checked everywhere under the drivers side of the dash. Does it have one or did I miss it? Going to be adding a turbo kit assuming that I can tune the thing.
itp
Re: 06 Eclipse 4cyl AT
Postby todd-w » Thu Feb 05, 2009 10:56 am
its usually taped to the loom just above the obd plug .
todd-w
Postby eshugo » Fri Feb 18, 2011 4:25 pm
So I know this post is over two years old but I can't seem to find it either.
Any help would be appreciated.
eshugo
